use wat to cut holes
Old 04-08-2002, 12:55 PM
Default use wat to cut holes
in lexan covers?
HuFFy is offline
Old 04-08-2002, 06:39 PM
Takumi's Avatar
Default use a reamer
A proper way is to use a reamer. This is a reamer from Hudy.
You twist and twist the reamer into the lexan until you reach your desired hole size.
Another way is to puncture a hole using a sharp object and then start filing the hole using a circular file.
Takumi is offline
Old 04-08-2002, 06:56 PM
drillbits..... 4 mount holes body and spoiler.
curve scissor ...... to cut vent holes. Tips for some cool web sites will show u how 2 mark and cut these holes
Good luck
Civic is offline
Old 04-08-2002, 07:38 PM
Kenneth Tan's Avatar
Use reamer lah
Kenneth Tan is offline
Old 04-08-2002, 08:18 PM
I use reamer, cutters, scissors and dremel ... ... heck, you can even use soldering iron! ...
stik is offline
Old 04-08-2002, 09:32 PM
AO
AO's Avatar
I got a small power tool between my legs
AO is offline
Old 04-08-2002, 09:44 PM
dtm
dtm's Avatar
So you are admitting yours is SMALL!!!!!
dtm is offline
Old 04-08-2002, 09:45 PM
dtm
dtm's Avatar
Sorry...it should be small
dtm is offline
Old 04-08-2002, 09:50 PM
AO
AO's Avatar
He he he he, You always like that.....
It may be small but but POWER...
AO is offline
Old 04-08-2002, 09:56 PM
dtm
dtm's Avatar
You have to be careful about what you post with me and Manticore lurking around!!!
Power is nothing without CONTROL!!!!
dtm is offline
Old 04-08-2002, 09:58 PM
... and do you use it on lexan??? ... just kidding, man ...
stik is offline
Old 04-08-2002, 10:00 PM
AO
AO's Avatar
Ok Ok Ok Ok..
You are right... You must have CONTROL ALL THE TIME>>>>>>> LAST TO THE VERY LAST SECOND>>>>> SQUEEZE THE LAST DROP FROM IT.... (Battery i mean)
AO is offline
Old 04-08-2002, 10:11 PM
dtm
dtm's Avatar
Ok Ok Ok Ok..
I think someone is going to 'censor' this thread any minute now!!!
dtm is offline
Old 04-08-2002, 11:06 PM
Old 04-09-2002, 03:49 AM
but some ppl hav big holes leh...i mean those to put the glow plug thru the body..or at the side for the starter cord..i dun wan jus circles...wat abt rectangles?
HuFFy is offline
