after run oil
Old 04-05-2002, 08:34 PM
Default after run oil
wats that? where can i get a good one?
frantic is offline
Old 04-06-2002, 02:31 AM
It's a hot oil which u need to apply after jogging and can get at any medical store or or can ask the 3 ladies at Orchard Plaza 2 away store before Winnie's.D
Rose Money is offline
Old 04-06-2002, 07:46 AM
not that time lah!
biang eh... that type that ppl pour into the engine one... acts like a lube i think... wat does it actually do and is it worth it?
frantic is offline
Old 04-07-2002, 09:39 AM
Trader Rating: 44 (100%+)
after run oil, recommended for:
a) breaking in a new engine
- flushing through the whole engine to get rid of any debris
- lubrication during break-in of new engine, esp if your piston/sleeve is very tight
b) lubricate your engine if you intend to keep it in storage for a few months
c) some pple recommending putting after run oil, after each run (duh). a bit excessive .. but of course precaution is better than cure.
wyl03 is offline
Old 04-07-2002, 09:58 AM
Best to use after each run .....
QuickShot is offline
Old 04-07-2002, 10:20 AM
MX3
i thought u never use even after the whole day's run??!!
MX3 is offline
Old 04-07-2002, 10:41 AM
I do.... if not after d run I'll do it at home .....
Old 04-08-2002, 12:15 AM
mix marvel mystery oil and automatic transmission fluid in 50/50 ratio and u get after run oil lor.
automatic transmission fluid alone also can.
huasze is offline
Old 04-08-2002, 06:12 AM
can you find Marvel mystery oil in singapore? been looking high and low for it.
wyl03 is offline
