Need Help For Cyclone S...
Hi Guy...
Need Help
(Any 1 Know Any Lipo More Then 4000mah And Can Put On Cyclone S??? .
Because From What I Tried A Lot Of Lipo Like Turnigy lipos 5000mah Cannot Put In... I Now Seaching, What Lipo Around 4600 - 5400mah Can Fit Cyclone S... Any 1 Know Any Brand Of Lipo That Can Put In Cyclone S???)
Thank Guys.
Must Be 7.4V 2S
Need Help
Thank Guys.
Must Be 7.4V 2S
Here u go
this is just an idea of what i mean
hope it helps!
photo 1 ; shows velcro attached through the opening in the chassis and slotted through a slot in the chassis.
photo 2 ; use two velcro straps to hold the battery down
photo 3 ; if you're using stick packs or flat bottomed lipo packs, your battery most probably will slide out eventually so i use a third velcro strap to hold e battery in place. not really necessary, just that i'm really anal about these things. Obsessive compulsive disorder hehehe!
BTW sorry for the crap quality, just quick snaps from my phone. hope you can see.
hope it helps!
Oh Harry Urs Is Carbon Mine In Plastic... Normal Cyclone S Plastic
Anyway Harry Thank For Ur Info And Ur Picture ...
i know i know, just to give example, but you can use a sharp hobby knife and cut a small slot in the cyclone s's plastic. I've seen it done before, albeit my friend did heat up the blade abit (recommended.)
also can try unscrewing the battery posts (the metal posts where you put your body clip in to secure the battery strap) a few turns to give abit more space for a larger lipo, height wise.
Ha Thank... But Mine Is My Upper Deck Block... For The Lipo Height... Ha Maybe Time To Upgrade Chassis ... Cyclone S I Think Mostly For Normal Lipo Not High Mah
Oh chey, should have been more specific.
Off the top of my head, there should be two ways to rectify this problem.
1st, modify your middle block R a little bit with a file. This isn't as daunting and hard as it sounds lol bro, just need a $8 file set from home|fix or, any neighbourhood hardware shop for that matter.
2nd, splurge on this lipo conversion kit from hotbodies. Thing is, it costs almost 3 figures (as far as i know) so i'd rather go w/ the former. Link to conver. kit
Pics ; see the part of the middle block where it's silver color among the blue anodizing? I've filed off a few mm off and now it can fit almost every lipo pack i have access to. Largest i've tried is with a trakpower 5000mah gold bar lipo, which is massive.
Woah Woah Bro Thank Alot For Ur Info... But The Lipo Conversion Kit From Hotbodies Is Not Out Yet... From What I Know... They Will Soon Be Available Ha But Not Out Yet...
