Xxx-s
Old 03-30-2002, 02:18 AM
Default Xxx-s
Just thought of creating a thread on XXX-S.
Any tips to share ?
Heard that a lot of people has been breaking stuffs on the XXX-S. What have you broken so far ? For myself, just 2 hub carriers.
ongbenghui is offline
Old 03-30-2002, 05:13 AM
front hub carrier as well.
the bumber is way too small.
else its a fun car. nothing much to tweak.
fuse01 is offline
Old 03-30-2002, 06:37 AM
kkyeo's Avatar
Great! Gives me a chance to get rid of this stuff.
U see, i bought these team Losi Springs but can't fit my Tamiya dampers. They are brand new though the package is open.
1 pair Orange Spring rate 8.6
1 pair Yellow Spring rate 9.6
anyone interested to get them for yur xxx-s, please PM me or email [email protected]
sell Cheap Cheap Lah.....
kkyeo is offline
Old 03-30-2002, 04:21 PM
I managed to mail order the brp bumper. Not sure
if it help so far, but it certainly more stuffer.
Old 03-30-2002, 05:33 PM
I think winnie's shop has run out of hub carrier.
But she got a couple of AE TC3 0 degree hub carrier
that has the same size as the XXX-S ones. The only
trouble that you need to file it a little to make the
CVD go thru.
Old 03-31-2002, 08:13 AM
Smile
we got our conversion kit and it came with the hubs..
cool stuff. i think xxxs will start to win some races.
fuse01 is offline
Old 03-31-2002, 06:51 PM
Is the conversion kit useful ?
I noticed that the weight saving may not be significant,
but I like the milling done. I find that the tub chassis seems
to collect sand & dirt. Couple of hole that make the sand
fell thru, I guess.
Old 03-31-2002, 07:28 PM
what ever it does, i have no idea but it look trick. and save a few oz.
fuse01 is offline
Old 04-01-2002, 06:18 AM
Hi fuse01, like to know where do you play your car and what is your setup like ?
Old 04-01-2002, 04:45 PM
MAX
MAX's Avatar
Ongbenghui,
Is your XXX-S new to you? If it is you should start with the factory set-up. It's a good start for all type of road condition. Form here, then you fine tune with different spring rate and shock oil.
MAX is offline
Old 04-01-2002, 06:28 PM
AO
AO's Avatar
Originally posted by MAX
Ongbenghui,
You old bird XXX-S driver come out and tell new bird.... Very Good....
AO is offline
Old 04-01-2002, 09:18 PM
Yes, The XXX-S is new to me. I am changing to blue spring
and planning to try out #57 shock piston. I would like more
traction. Any advise.
Old 04-01-2002, 10:19 PM
MAX
MAX's Avatar
First, consider the right tyre compound for the ground condition.
Do you have a short shock for the front?
Alway remember, do not change so many thing at one time. If any thing goes wrong, you do not know which setup went wrong.
MAX is offline
