Hi!
Old 04-25-2002, 01:02 AM
  #91
fIShCaKe's Avatar
Hey Vifer, save the cost of changing a brand new differential man... Times are bad. Open up the old and dirty one, clean it up and reuse! Whahahaa...
fIShCaKe is offline
Old 04-25-2002, 08:33 AM
  #92
lonestar1127's Avatar
vifer sorrie i cannot go ms on sat cause last minute kena call to work
lonestar1127 is offline
Old 04-25-2002, 09:18 AM
  #93
Vifer's Avatar
No problem lonestar, work is more important at time like now. Anyway, hope to meet you on the track one someday. I am quite free til the 5th of May.
Vifer is offline
Old 04-25-2002, 09:20 AM
  #94
Vifer's Avatar
I guess I will be cleaning up and refilling it for now. Just want to setup the car properly so I can play with ease in mind.
Vifer is offline
Old 05-01-2002, 11:03 AM
  #95
Default Re: Differential
Originally posted by Vifer
Since we are into differential...
Anyone mounted another extra set of bevel gears (making a total of 4 gears) into their diff unit? (Originally only 2)
What's the advantages?
BTW, what's the recommanded silicone oil rating for the diff unit?
I read someone's posting about 50k and 30k, another posted 30k and 5k respectively in front and rear units.
Finally...anyone using the active differential unit from Team Kyosho (Blue casing) or
Kuwahara (Silver with internal clutch system)
Need replacement on my unit coz the rear had almost dried up from leaking.
i think the other posting abt the 30k rear and 50k front u r refering to is my brother's.
now both our cars are running this setup(as recommended by those old birds at ms)
the setup seems fine to me...
HuFFy is offline
Old 05-01-2002, 10:50 PM
  #96
Vifer's Avatar
Default diff oil
I dumped in 30k and 5k respectively last Saturday and tested on the track yesterday. Not bad, can turn more properly now. Just need to get the suspension to setup properly. After putting on the rear sway bar, the car kept flipping at high speed sharp corner.
Using trinity 90wt wif hard spring in the front and 50wt wif med spring in the rear shocks.
Front 0 camber wif 1 deg toe-in
Rear -2 camber wif 1 deg toe-in
Planning to change the rear sic oil to 90wt too.
Any suggestion?
Vifer is offline
Old 05-01-2002, 10:59 PM
  #97
oops,...paiseh..its 50k front 30k rear..heh
HuFFy is offline
Old 05-02-2002, 09:04 AM
  #98
vifer u going down this weekend?
Old 05-02-2002, 10:40 AM
  #99
Vifer's Avatar
If there's no last minute appointment, I guess I will be at MS abt 2pm.
BTW, I will be doing some setting and fine tuning tomorrow(Friday) at MS too. Drop by if you are free. I should be there around 2pm. Trying hard to solve the flipping problem.
Vifer is offline
Old 05-02-2002, 10:50 AM
  #100
i maybe going down to ms... tomoro or saturday too..if u see a super slow 2 colored skyline hogging the track...yep tats me
HuFFy is offline
Old 05-03-2002, 09:05 PM
  #101
Vifer's Avatar
Thanks for the clearing up. I had tested my car setup yesterday just before heaven decided to drop some cats and dogs. My car can smoothly slide into corners and power out now. No more flipping. I guess my car won't be named "Flipper" again.
Vifer is offline
Old 05-04-2002, 05:45 AM
  #102
were u there today?..saw a quite of v1rs today at the track..
HuFFy is offline
Old 05-04-2002, 08:53 AM
  #103
huffy u were there?
Old 05-04-2002, 09:07 AM
  #104
Vifer's Avatar
Default Marina South
I was at MS just now. Arrived at about 3.40pm. It started rainning just as I started my engine. I am the one with one arm in sling. Hogging the track with my slow yellow stratus. I sat with the group of friendly "uncles".
How do I recognise the rest of you? Tried looking out for a two coloured skyline but to no avail.
Salute to those lao jiaos who helped drying the track today.
Vifer is offline
Old 05-04-2002, 09:49 AM
  #105
ya i wus there...the red hair one ...
was with my brother...in the blue shirt...
left soon after it started to rain~
HuFFy is offline
