need drift pros to advice me if i can use a HPI-Drift Motor 19T on a tamiya tt01 ?
hey guys and girls . can some one tell me if i can use a HPI-Drift Motor 19T on my tamiya tt01 drift . i have worked a lot on it but never did change my engine and i feel like its time .
so fellow drifters let me know if this is possible , thx
I may not be a pro but i could tell you that you can put it for drifting
no problem
what esc are you using?some escs are not able to take 19tmotor,it will fry your esc
Bro first you need to check if your esc is able to power up a 19t motor. Secondly you need to ensure that you do not over gear your motor 6.0 final gear ratio is safe enough. To change your gear ratio, you will need to change your pinion gear and maybe your spur gear as well.
it'll depend on which ESC u're using. if u're using the Tamiya TEU-101BK esc, please do not use this motor as it'll cut off(thermal shut-down) in less than 3 minutes of use.
if u're using a Futaba MC330CR and above, then its not a big problem. but 1 thing, i'll recommend 24(pinion)/58(spur) for your gearing. u'll get the torque u need for drifting.
Hi,
Join more drift meets or Drift Competition you will know.
The purpose is to learn, but not aim to win at the beginning stage.
