formula-1
Old 06-15-2002, 09:27 AM
  #226
Jack's Avatar
Originally posted by fReShJiVe
hahaha! i like to read gossips!
i'm also using 3x3 batt on my cross in the inline position...maybe u could PM me where u live if it's nearby me...i can drop by to pass u the body
near kallang.. it okie actually when u are at the track then u pass to me..
hmm where is the gossipbe??
how come i dont know about it.....
but my 3x3 is with corally plug and the esc that is on the F1 is using dean...
Jack is offline
Old 06-15-2002, 09:33 AM
  #227
ok than i'll pass u at the track!mine is on corally plugs in all my cars ....so just tell me when u r going MS
fReShJiVe is offline
Old 06-15-2002, 09:59 AM
  #228
Jack's Avatar
if nothing goes wrong. then we will go down to MS on sat morning with our touring.. u hava a touring as well right.. if u do. just bring it down as well
Jack is offline
Old 06-15-2002, 10:07 AM
  #229
ok then next saturday
Old 06-15-2002, 05:55 PM
  #230
ozone's Avatar
alvin, reason y i suggest u to use 48pitch is bcos, after several intense runs, the motor tend to shift a bit which will result in the spur gear to strip(normally if i run 64p...never check the meshing b4 i run again )...not cost effective...
hpi has a spur gear for f1 in 64p...comes wif the balls and a plastic stuff(dun noe wat to call it)...get tat...u need the balls and the plastic stuff so u can use 48p...so far i manage to mount 75 and 81 tooth on my f103 wif the adj rear motor mount...next time show u...if u need small AV pinion...can borrow u...so i hav another kaki playing 2WD DIRECT DRIVE...although it is a F1 in disguise and not a real pan car
ozone is offline
Old 06-15-2002, 11:46 PM
  #231
Jimmyd's Avatar
Alvin: I forgot to pass you the AV pinion gear I have one that I am not using anymore. But with the stock spur and this pinion the FDR is 3.75 so only suitable for sport tune motor. You can run a 24deg stock with this gearing but must be very conservative on throttle or you will fry the stock.
Ozone: You got a point there. 48p seem to be a trade off between durability and efficiency. Where do you get the HPI stuff? Maybe the kimborough gears at winnies shop might fit. I have replaced three 64p spurs so far. The last one just yesterday so I hope this one lasts. I think the problem is not with 64p but the tamiya design. On my corally the spur is narrower than the pinion and the edges are tapered but the tamiya spur is wider than the pinion which makes the edges more prone to damage. My corally spur is still good as new.
Jimmyd is offline
Old 06-16-2002, 12:03 AM
  #232
Jimmyd's Avatar
Alvin: I found a nice gtp body at Taising yesterday. Its a cross mercedes CLK gt1 very low and sleek looking. Go get that one. You still need the gt bumper for mounting gtp bodies. The ta04 bumper is too thick and will get in the way of the body.
If you did manage to fit that 04 bumper and get a sedan body mounted then by all means play with that body first
Jimmyd is offline
Old 06-16-2002, 09:19 AM
  #233
Alvin's Avatar
hey great thanks for the tip.
BTW, I replied to the motor thread and reminded to ask you guys, do you run lighter springs when you run pan cars? The orion website seems to indicate e.g. 90degree springs more suitable for panners, not tourers.
Alvin is offline
Old 06-16-2002, 09:57 AM
  #234
Jack's Avatar
pan car u can use lighter spring. cause u dont need much torque. since the rotating mass is much less
lighter spring equate to more rpm
as harder spring equate to more torque..
dont worry so much on the spring.. since u are not racing.. just use what spring the motor come with...
Jack is offline
Old 06-16-2002, 09:04 PM
  #235
Jimmyd's Avatar
Light springs are not so good if you run at yuanching since the track is so technical and bumpy. I normally use the supplied springs.
Jack: Is your car a 10LS or a 10L2? How do find the handling?
Jimmyd is offline
Old 06-16-2002, 09:08 PM
  #236
Jack's Avatar
10LS..
handleing is good if the correct foam is use..
Jack is offline
Old 06-16-2002, 11:39 PM
  #237
jack - so what foam compound/brand did u have sucess using??and for which track?
Old 06-17-2002, 03:18 AM
  #238
Jimmyd's Avatar
Hey F1 racers go check out the Corally F1 at Hobby Boom that Andrea is selling. The condition is very good with hardly any wear. The chasis bottom did has some scratches that you can expect after 2-3 runs. So its a good deal at $250
Jimmyd is offline
Old 06-17-2002, 06:59 AM
  #239
Jack's Avatar
where is this hobby boom???
I cant rem what foam i was using.. the colour code was gone from the rim
if i rem correctly. i think it was green rear and blue frnt at jurong..
Jack is offline
Old 06-17-2002, 08:11 PM
  #240
Jimmyd's Avatar
Excelsior shopping centre just behind Funan centre. The shop is B1 they have a nice miniz track too.
Jimmyd is offline
