Go Back  R/C Tech Forums > International Forums > Singapore R/C Racers
Ball bearings for the TA-04 Aluminium Pulley >
Old 03-04-2002, 05:36 PM
KiwiKid's Avatar
Default Ball bearings for the TA-04 Aluminium Pulley
Hi,
I'm interested in replacing my 3 mm balls in the front and rear aluminium pulleys of my TA-04 with 3.9 mm balls (which I was told will do away with the need for the plastic inserts). Any ideas as to where these can be purchased and the likely cost?
Many thanks.
p/s - Jeff, I hope you read this thread.
KiwiKid is offline
Old 03-04-2002, 08:58 PM
Firstly check with Tai Sing as their bearings are Tamiya original. If don't have, go to Winnie.
Hey u guys! I'm back...
Rose Money is offline
Old 03-04-2002, 10:06 PM
Kenneth Tan's Avatar
Are you talking about the aluminium diff pulleys? Is there a reason for removing the plastic inserts? I thought the plastic inserts are supposed to reduce friction?
Kenneth Tan is offline
Old 03-04-2002, 11:01 PM
AO
AO's Avatar
Lightbulb
Kennth,
Use the insert first when the the insert is worn out.
Then chance to 3.9mm balls.
Both ways are correct. but with the 3.9mm ball you may wear your pulley.
See you
AO is offline
Old 03-05-2002, 03:25 AM
ozone's Avatar
welcome back rose money
ozone is offline
Old 03-05-2002, 08:36 AM
Hi... I think I was teh one whom put the idea in his head... well I agree with AO, use the plastic cups 1st till they wear out, you shld not use the 3.9mm balls for a rough track, but for a smooth track like the one in marine parade is much smoother therefore using the 3.9mm balls still work.
Btw to get those 3.9 mm balls go to SK bearings at seragoon road (near little india) you can also get the 3mm balls that we normally use in bulk there so you can change them every 5 races or so.
Madman is offline
Old 03-06-2002, 01:15 AM
KiwiKid's Avatar
Thanks guys. I shall stick with the 3 mm until the plastic inserts wear out (as mentioned).
KiwiKid is offline
Old 03-08-2002, 11:00 PM
Alvin's Avatar
Dudes,
any idea where to purchase sealed bearings? Want to use on TA04. If the hardware shops sell cheaper VS the tamiya original bearings then oh well get tamiya.
Thanks.
Alvin is offline
Old 03-11-2002, 05:29 AM
Trader Rating: 44 (100%+)
you can try Kian Ho bearings along Jln Besar, or SHinko bearings near Lavender MRT. i've tried both before.
i just bought a set of rubber-sealed bearings for my MP7.5 from kian ho last saturday. not sure if it's a whole lot cheaper than hobby shops but at least i know i only need to go to one location to find bearings rather than hunting high and low ...
wyl03 is offline
Old 03-11-2002, 05:40 AM
Alvin's Avatar
Not bad, they have a pretty cool site @ http://www.kianho.com.sg
Thanks wyl03, I will check them out soon.
Thanks and best regards,
Alvin
Alvin is offline
Old 03-11-2002, 06:38 AM
Hi,
Sounds interesting. any idea what is the price like ?
ongbenghui is offline
