Best lipo Chargers and battery (for budget racer)
#31
Dun ya ya papaya hor!
Can't be bother with wat storage I got time I bring to race or wet market n bash
Don't even know the storage voltage wanna play 6S lipo?
http://www.rcgroups.com/forums/showthread.php?t=638029
In short, it's recommended by Flightpower to store at 3.8v per cells. In case you dunno what is flightpower, it's one of the better and expensive Plane/heli lipo out there.
Whenever u buy new lipo check the voltage per cell voltage it should be around 3.8 to 3.9 per cell.
#32
Feel free to go and see and ask when people play (There are lots of drift meets and EP race around) see what they use and ask for advise. Doing paper research is good but see for yourself will learn more.
#33
Was able to get A 3p2s Venom Saddle pack config 6000Mah @ 40C, but still a bit confused on what to get for my charger, can a Hyperion EOS 1210i-A support this type of batt since there are 3 batt in parallel and 2 in series?
if not what can be the best charger for my batt.
Thanks,
#34
Thanks,
Thanks,
#35
EOS 1210i is a DC charger right?budget well, if its reasonable then i will get it but what can you suggest, from low, mid and high end. How much and where to get it.
Thanks in advanvce.
#36
Thanks in advanvce.
Thanks in advanvce.
Configuration: 3P2S
Weight: 360g
Dimensions: 31 x 46 x 69 mm
Charge Rate: 5C (30A)
Continuous Discharge: 30C
Min Discharge Volts per Pack: 6.0V
Max Burst Rate: 40C
Max Volts per Cell: 4.2V
Max Volts per Pack: 8.4V
y u buy 3P? Do u know the lesser P the better?
U need a charger that can do syn charging. Usually it's high end chargers.
#37
Thanks in advanvce.
Thanks in advanvce.
#38
This batt?
Configuration: 3P2S
Weight: 360g
Max Burst Rate: 40C
Configuration: 3P2S
Weight: 360g
Max Burst Rate: 40C
Yup, i think thats the specs of my lipo, sorry just new to lipo. but what can you recommend for this type of battery?can a Hyperion EOS 1210i-A support this type of batt?if not then what can i use to charge my batt?or opt to change it for a lesser P, maybe a 2s1p???? any help will do.
Thanks in advance.
#39
Thanks in advance.
Thanks in advance.
Cells is better bundle as 1P becoz cells can be unbalance & worst the esc cant detect individual cells to do a cut off so the worst scene is some cells will go lower than 3v n get damage.
That y 1P lipos are more expensive than 2P n 3P.
#40
Most Hyperion charger can charge your batt. Try to change to 1P 2s lipo rather than many P.
thanks again.
cheers!!!!
#42
hey guys, has anyone ordered the gens ace saddle
http://www.nitrorcx.com/98p-25c-4800-2s3p-saddle.html
from hobbypartz and co? does it come with wires/connectors as shown in
http://www.rc-battery.com/app/menu.p..._product&id=95
or just two batteries? thanks.
