1/18 RTR Buggy/Truck/MT electric
Does anyone knows where I can the above? Or seen any? any brand will do, most impt is parts replacement and upgrade.
I tried Taising they only got minizilla, which i feel the support parts seems low. Waiting to see Brama 18b, but they also dun know when come. Toykar, ran out of mini inferno.
Any advise appreciated.
Thks
Jerry
Thks
Jerry
Other than the mini inferno, 1/18 off roaders doesn't seemed to be as well received as the on-road counterparts.
I have a mini-LST which I've upgraded to brushless clocked to around 50kmph. The mini-lst needs tons of upgrades/mods so that it can run well. These upgrades can cost well above the mini-lst itself. It is known to have very weak diffs and the steering setup sucks big time. Parts support in SG is almost nil. So this means that u will be paying alot for shipping if u insist on gettting this truck.
The new mini E-revo should be quite a good performer. So far since its release, I have yet to hear of diff problems. The vehicle is designed for brushless power. The stock brushless setup can push the mini e-revo up to 50 mph depending on the batteries that are used. I intend to get one mini e-revo.
RC18T don't really have part support locally but i've heard good things about it being a very good racer.
http://r2hobbies.com/proddetail.php?prod=rcve00045
Check out the link for this rc18T clone that sports a very good FM computer radio.
Thks
Jerry
Thks
Jerry
Ray
I go read the item up on net. thks. await yur reply
Jerry
Stocks will be available mid July. Full hop up version will also be available then.
I'm leaving for China this afternoon. Just PM me if you need more info.
Here are the specs:
F18 comes with LPR Rims and Tires, just like the 1/8th to increase
the driving performance and stability.
Equipped with Threaded Mini Big Bore shocks.
1.5kg steering servo is used to give the car plenty of power to turn.
SPEC:
2030 130s Brushless Motor.
Hobbywing High End Brushless Speed Control (25A.)
Pre-printed Buggy Body and Truggy Body.
1200 NIMH rechargeable battery
Battery charger 350amp
AM radio with EPA functions.
Fully upgradable to Full Option Kit
1.5 Hex Screws all around.
Racing style downforce wing.
Full Ball bearing
Gear Ratio:10.7:1
4WD
L*W*H: 25.0*17.0*10.5cm
Ray
thanks man. Keep me inform. I m keen
