Any Tamiya F-350,Hilux,Tundra
#61
Hi I dun see why not. I've tried the DX5e on the MFC and it worked. The only issue I had is getting round the trim issue (you need to set certain trims to it's lowest in order to activate certain function and with the DX5e digital trims. you have to keep thumbing on the trims all the time till you reach the lowest setting - this I find is troublesome)
I'd choose TX that allows me to set trim to jump by say 4notches or 10 notches at a single click.
Hope this helps
Hope this helps
#62
#63
y this thread sudd goes dead?
#65
Some and Pix I took last Sun. Brilliant weather for trucking...
http://www.youtube.com/watch?v=vAckS1YR6RA
#66
Buying Used Truck
Hi All. i am new here.
Any one can share/review about the Tamiya 1/10 Truck. keen in getting one.
Any one selling the 1/10 Tamiya Truck like the TUNDRA here? Or maybe going to buy new set.
#67
#68
Monkey Business
Trucking at DairyFarm's certainly interesting! There's no cow, no milk...but Monkeys. They became our only spectator all Sun morning!
Here's the Vid...can you spot them.
http://www.youtube.com/watch?v=tDETMO6Rsts
No bananas but trucks, they must be disappointed
Fellas, come join us one of these days!!! This place can accomodate a fleet of trucks.
#69
#70
I'm experimenting with the benedini sound module from Germany on my Tamiya CR-01 unimog and it sounded pretty good!
Flick the assigned 3 way switch on the TX & you start the engine.
Throttle forward and you get the proportional engine sound reving up.
Engine idling and hissing sound will be heard at neutral throttle.
Flick the switch on the TX back and you get the horn sound.
Plus...you can program and record your own sound with this module....like the scolding the "#?@!" word when the front driver is kayu.
It cost abt 50-65Euro (you need the optional usb cable to transfer sound from your PC to Module though) but it certainly add true scale and realism to my single speed trucks and crawlers.
I will post video soon.
great find.. can you point me to the exact model because i can t seem to find the right one on their site ? all the ones i see are more expensive..
thanks !
P
#71
I run stock silver cans on all my trucks. Only my AX-10 and Losi Crawler runs brushless (which is a 55T brush equivalent).
I like the silvercan cos it's all weather and can take quite a beating. I run the LRP AI esc on the pajero (under S$90 and it is fully waterproof).
My friend's truck is also fairly bulletproof for all weather. All joints plus lighting connections are fully sealed with high temp sillicone seal (aka transparent fishtank rubber seal).
Cheers!
#72
Let me dig deeper and I'll let you know asap.
#73
When are u guys trailing again? I have a Pajero and yet to run it... Been wanting to find kakis and learn more about this hobby...Still new to it..
#74
