TT01 Sharing thread.
#46
What sorta tyres should i use if i want to make an offroad rally tt01? Tamiya radials?
#47
link: http://www.etamiya.com/shop/tamiya-5...es-p-3670.html
#48
hi guys just got a tamiya TZ motor with metal motor mount. Can i use 25T/55spur ? I doent seem to be able to mesh the pinon and spur, its either too tight or loose. Please advice thanks
#49
u might want to try using a 24t pinion and see how it goes. i believe that u have already tried mounting the motor in different mounting holes.
this is one of the limitations of TT01: restricted motor-mounting positions.
#50
the gears should mesh perfectly since 25/55 is one of the most common TT01 configuration.
#51
Guest
Noob need help...token of appreciation given
Hi, i'm a 33 yr old noob that needs help with my 2 TT01-D (one is bought used & one is brand new self assembled) , need a advance mechanic to "look at, educate & possibility of fiddling" the set up of my cars. Staying at Chai Chee & Bukit Panjang (yeah, two houses, damn confusing for me too). Let me know which location to meet up. I really need help. Bought the the cars in January 2008 & have not even run in yet till now. A small token of appreciation is given after helping me with my cars. Pls. contact me at 92363 048 (Jae) or email me at [email protected] for further discussions. Thank you.
#52
u might want to drop by some of the drift meets at your convenience to seek help.
link: SG Drift Meets
#53
Hey bros,
i'm a tt-01 noob here. Been drifting for a few months only...
I recently bought a carbon upper deck and the f&r stabilizer sets for it...
thing is, i have no idea how to mount the front stabilizers!
Anyone can give me a solution? And maybe a few pics? All help would be greatly appreciated!
#54
Hi guys!! Im also a noob and i would like to know if there's any good settings for the tt-01d to drift better. thx
#55
Hey bros,
#56
[QUOTE=Freaked;6142492]Hi guys!! Im also a noob and i would like to know if there's any good settings for the tt-01d to drift better. thx[/QUOTE
bro there is lots of difference setting from difference ppl preference. You might wana look through the thread for more info.. Cheers
#57
So already has the adjustable upper arms as a standard... but i either don't have the mounting hardware or i don't know how to do it...
Cause i bought the upper deck & stabilizers as a used set.
Can someone pleaaaaaaaaaaaaaaaaaaaase put pics of the stabilizer set mounted @ front? Thanks!
#58
Wait, i forgot to mention that i'm using the tt-01d...
#59
Oh... thanks! Kudos on the creativity!
But, for drifting, using both F&R stabilizers, is it advisable?
Some people say that takes away chassis roll, which is unadvisable...
But the tt-01's stock weight balance issues is killing me, and this is the only solution i could think of...
#60
