Help on Mini Inferno 09 ARR
Bros,
I need help, got i new mini inferno 09 ARR and i found out some thing i very confuse. The wheels does not turn correctly leh, seem that the I can`t push the car at all when i try to. I checked the brakes and they are free. I lifted the car when both front wheels turn clockwise the rear wheels turn anti. Try turning single wheel and feels very stiff, all the same. Is it like that or something is wrong on the gears when Kyosho assemble it? Please help |
if you try to turn your front wheels forwards, and the rear wheels rolls backwards, that means your differential is placed on the wrong direction.
Originally Posted by Dryft
(Post 5936265)
Then what should I do? Disassemble the gear box? If so, which side should is the right setting? Thanks |
(Post 5936265)
Thanks again |
