Interest Check on Kyosho dNaNo FX-101
Hi All,
Just wish to check anybody have come across the above mentioned and any comments abt it...
More info as follows :
http://www.kyosho.com/eng/products/r...5=&s6=&s7=&s8=
Suitable to play on carpet track...
Hi All,
From Toykar website, the kit cost $199 without radio...
And I think the kit without radio does not come with the lipo charger and battery that is required for operation...
Probably it will cost $300 to start up...Would love to get one if its within $200 to startup...
Info from the dNaNoshop:
If you want to change bodyshells, you need to get the bodyshell fitting kit that comes separately from the bodyshell...And each bodyshell has its own kind of fitting kit...
So its kinda expensive if you want to change bodyshells...I would stick to the older versions which is cheaper overall...
yo... hmm... the price is ard 300++ region... if compare with starter kit mini z, i tink this is ex... but come to tink abt it, it has 2.4ghz tx and personalise info connect with net, etc... also quite worth it...
You are right... Price to start off is $358 ($199 for car kit / $159 for starter pack)...
hmm unsure abt the bodyshell fittings... If the price of shell and fitting kit is reasonable, i think still worth to buy... unless it is more ex than the current kind(mini z), then i tink not worth to try...
