Tamiya TA05 IFS R
#31
Tang I have checked all the settings. Length of turn buckles are according to Tamiya instruction book. I am not sure how you will shift the weight in this car because there is not much u can move in there. ESC is sitting right behind the motor and receiver in front of the motor. But they do not weigh much or still some effect? I have tried to reduce understeer by giving negative camber angle of front suspension but felt nothing at all.
#32
#33
Hi Tang,
I have increased toe-out angle. The handling improved significantly but I am still suffering some understeer problem. Cheers NJ
#36
#37
It depends on the track surface. Popular brand here is Sorex 36r and 40r.
The damper oil will also change the way the car handles.
#39
OK thanks mate. I am trying to get stuff from AceHobbySinapore but having no luck. can you suggest any other supplier who can supply everything.
#40
Finally got real motor. LRP Sphere Vector X-12 5.5. It looks so great and cool. But hey I can not find sensor cable???? it did not come with ESC and it did not come with motor. what a headache to try to get cable again. Does it make big difference if you connect motor to sensor system in ESC????
#41
I am not sure if those tires will be able to handle well in your climate. I guess you are better off asking fellow forumer with similar cold climate like your country. If I do drop by mongolia, I can bring them to you and you can treat me to Metropolis.
#42
Hey, welcome man! In fact I have just completed constructing RC track. First RC track in Mongolia. this is asphalt. Surface at some places become bit bumpy I don to know how to fix that. But hey that is a lot of grip. Straight line is 35+ meters. If you do come around I will treat you well. Anyone else who wants to try first RC track in Mong welcome!!!!
#43
#44
I am still working on corners and kerbs. As soon as I complete i will place picture. But November will be very cold. If you want to come it must be no later than mid September.
#45
I will pm for details about the trip.
