Question on L.R.P. A.I. Runner Plus Reverse
Dear All,
I have an L.R.P. A.I. Runner Plus Reverse. The wire from the speedie to the battery was in Tamiya Plugs. I had then cut top part of the wire away, and had soldered T plugs (deans) on.
The mentioned wire is now shorter than when I first had them. Will I be able to totally remove the current wire and replace it with a new set to my desired length?
Dear All,
Alternatively, connect extra wires of your desired length & solder to your existing batt wires. Cover the exposed wires with shrink tube. Safer.
Hi Teinsports,
I know I can strip the existing wire and "extend" it from there.
But I had the idea scraped as it will generate more resistance, as compared to a single wire; thus the lost in performance.
I am actually thinking of opening the case of my ESC to make a singular wire possible. Has anyone done it before on the mentioned ESC?
Hi Chin,
you can open up the casing and solder the new wire onto the circuit board, just have to be very careful with the excess solder. don't let it spill onto the other parts.
personally i'd advice you to extend the wire. yes, there'll be more resistance, but it's negligible, considering the grade of esc that you have. It's not a bad esc, i have a similar one from lrp as well, but if you compare the specifications to higher end escs, the internal resistance is quite alot higher, especially since it has reverse. so unless you don't mind the risk and extra effort, just extending the wire will do yup
zipp
zipp
