Go Back  R/C Tech Forums > International Forums > Singapore R/C Racers
Newbies Queries - Ask and you shall be answered! >
Like Tree1Likes
Old 04-30-2006, 11:50 PM
  #1471
Sp1ke's Avatar
Originally Posted by wolfman
my MT2 centre gear was 49T and running with good speed & torque
but when I change to 52T, it start up very slowly when you full trigger and the fuel run dry very fast.. less than 5min per tank.
whats the problem.
need info & help.
thanks & regards.
A thing to remember: the BIGGER your number of gear teeth, the MORE your engine will have to output to get 1 revolution of the pinion gear... meaning, if you want more speed, drop the number of gears.... if you want more TORQUE on rough terrain, go up A GEAR AT A TIME... dun go up by too much... when you do that, it messes up your engine settings... thus it has no fuel economy, AND your engine will run very2 hot (to keep up with the high output).... with proper settings, the spur gear may still be used if you wanna play offroad...
Sp1ke is offline
Old 05-01-2006, 11:57 AM
  #1472
Originally Posted by Sp1ke
Bro... the high peaking is normal since:
1. Your pack is NEW...
2. Your pack is most prob a matched pack(does its have a sticker on every cell?)
hahah but never exp a 3300 to hit 4000 before leh... only 3800... hehehe... wah! means your cells better than mine... hehehe... have fun with them... and take care of it...
yup. thanks so much for your advice. anyway, has anyone got any views on how to managed and take care of yr cells properly? the correct way? Have been hearing alot of different views. Like how to properly discharge, charge. Should the batteries be discharged if not used for like more den 3 days? Anyway, I am using a CDC 6.0b charger and have got a team orion discharger. I dont have any tray or equaliser and things like that. Is it really necessary? Please advise. Thanks!
Melvin. is offline
Old 05-04-2006, 12:24 AM
  #1473
Cirrc's Avatar
Default Xray T1R Raycer
Anyone know where I can buy a new Xray T1R Raycer?
Thanks in advance.
I know that Xray has just released the T2, but I'm not looking at something that expensive.
Cirrc is offline
Old 05-04-2006, 01:44 AM
  #1474
KOLORS's Avatar
Thanks in advance.
check with hobbylink...http://www.hobbylink.com.sg/ ...if ever you can find any still selling a new one in SG...should be them.
KOLORS is offline
Old 05-04-2006, 03:15 AM
  #1475
Hey i got my car 5 days ago, its a Tamiya glow Engine R/C car XGB, it is my first Nitro car i have owned, and i am experincing problems wiht the radioactivity from the controller to the car, when i turn the remote on and the car on, the accelertor lever on the actull car goes out of control and does what it lieks, after this you can not turn the wheels, accelerate or brake with the remote, i can start the car, but the accelerator knob goes crazy and makes my car go out of control and up walls, i need serious help, i have taken the crystals out and put them back in, as i said im new to this so i dont no all the terms, Cheers
Jay_Jay is offline
Old 05-04-2006, 05:03 AM
  #1476
is your Rx Batt pack weak? charge your batt pack and see what happen
technicapot is offline
Old 05-04-2006, 11:58 PM
  #1477
wendzg's Avatar
Default ESC for stock motor
Hi guys! is it safe to use high speed motor ESC's for a stock motor? Like the Novak rooster reversible? Thanks!!!
wendzg is offline
Old 05-05-2006, 12:53 AM
  #1478
Ultra_Magnus's Avatar
It should be safe as long as u do not use a 23Tlimit esc with a 10T motor.
Ultra_Magnus is offline
Old 05-05-2006, 01:13 AM
  #1479
40%
40%'s Avatar
This sound like glitching with your radio.You might have
1. Faulty AM crystals
2. Faulty receiver
3. Stripped gears in the servo.
If you really not sure on what to do bring back to where you bought it and tell them of the problem. With luck they might give you a set of new crystals
40% is offline
Old 05-05-2006, 03:03 AM
  #1480
Thanks 40%
Jay_Jay is offline
Old 05-05-2006, 04:49 AM
  #1481
40%
40%'s Avatar
Thanks 40%
No worries.
40% is offline
Old 05-14-2006, 07:24 AM
  #1482
Default total newbie needs help
Hi, the last time i had a RC car was almost 20 years ago with my Kyosho Ultima. Thought of starting up again. Any advice? I've been reading up on this site and I'm thinking 1/10 EP.
1.Does anyone play with the F1 cars regularly?
2.Or is it better to get a touring car like TA05 since thats what most people are playing with now? Recommendations?
3. What about Tx and Rx? Should I invest in a better one that can control 3 cars etc? What should i look out for?
4. What are factors should i look out for? Batteries? Chargers?
Thanks so much
imrog is offline
Old 05-20-2006, 10:39 PM
  #1483
Alfie's Avatar
Trader Rating: 17 (100%+)
Hi guys!
Pardon my ignorance. I would like to know if this products could be used on a Duratrax ICE Charger:
1) Great Planes Electrify GPMM3151 Thermal Probe (GPMM3151)
Well, needless to say that the Duratrax DTXP Thermal Probe for the Duratrax ICE Charger can be used on the ICE.
Also, where can I buy these 2 probes? Haven't been around much to know the directions.
Thanks in advance!
Alfie
Alfie is offline
Old 05-20-2006, 10:57 PM
  #1484
Yes the temp probes are the same. Tower has them.
Just Gundam is offline
Old 05-21-2006, 07:42 AM
  #1485
Alfie's Avatar
Alfie is offline
