Go Back  R/C Tech Forums > International Forums > Singapore R/C Racers
Newbies Queries - Ask and you shall be answered! >
Like Tree1Likes
Old 12-31-2005, 07:16 PM
  #1366
maskedrider's Avatar
Originally Posted by orb_dharma
Yup that's what exactly happens when I'm running it.
Batteries used: Sanyo 2300 NiMh / GP 6v Hump Pack
AM 27Mhz receiver / transmitter
Cables seem to be tidy
What else should I be looking out for? Help......Help
Better bring it down to hobby bug for help...it's better to let the boss there to see and feel your problem and solve your problem right away , rather then having a guessing game
maskedrider is offline
Old 01-01-2006, 01:59 AM
  #1367
csm87's Avatar
Default looking for a budget motor
hi,
i'm looking for a budget motor with good run time, providing equally good speed n torque. used for carpark bashing. any recommendations?
csm87 is offline
Old 01-03-2006, 09:09 PM
  #1368
nixaad's Avatar
Originally Posted by csm87
hi,
try silvercans. good run time, good speed if ran in properly, gear up for torque.
nixaad is offline
Old 01-05-2006, 05:00 AM
  #1369
csm87's Avatar
Default advice on tires
edit
csm87 is offline
Old 01-05-2006, 06:58 PM
  #1370
gtr206's Avatar
Hi guys...a newbie here just to ask some tips. How & what do you use to clean the motor's amature and brushes and also how often?
Cheers,
gtr206
gtr206 is offline
Old 01-05-2006, 10:21 PM
  #1371
nixaad's Avatar
Cheers,
gtr206
Welcome gtr206 to the world of RC. It's all about discipline when it comes to 'CLEANING'. Anyway, make a habit of cleaning ur motors before you leave for home. DO NOT FORGET to lubricate the bushings before storing it away.
To clean the motors, use the motor cleaner, Eagle brand is most recommended by myself, but a tad expensive. Tamiya has one too, checkout BK, he has plenty of motor spray. Open up the endbells and pull out the armature, don't forget to remove the brushes first, also remember how many washes there are at each ends of the armarture and don't lose them. Spray the whole armature, inside the endbells, airgun it if a compressor is around, or u can let it dry. Most importantly, DO NOT, I REPEAT, DO NOT BE NEAR TO OPEN FIRE WHEN HAND IS WET WITH MOTOR CLEANER. Ask jake.
nixaad is offline
Old 01-05-2006, 10:38 PM
  #1372
gtr206's Avatar
Hey nixaad, thanks for the tips. This will really help me lots. I hope Jake is alright dude...thanks again.
gtr206 is offline
Old 01-06-2006, 06:34 PM
  #1373
sty
sty's Avatar
Jake is alright. Thanks to the hero of the day and that is nixaad. Btw, gtr 206, my motor is already not of that "Superior quality" anymore. Should not waste to much money on it. If u r seriously going to race, should get afew new ones and prep them for race. In racing, everything counts starting from the motors, batts, setups and tyres. Will pop by tomorrow at BK to see u race.
sty is offline
Old 01-06-2006, 08:15 PM
  #1374
gtr206's Avatar
Hi sty, your motor is alright and running fine. I'm pretty happy with it and thanks. Also thanks for all your support...see you 2morrow...
gtr206 is offline
Old 01-09-2006, 05:28 AM
  #1375
Default QNS!
hi
anyone know if petrol can be used in the engine?
wei25 is offline
Old 01-09-2006, 06:02 PM
  #1376
Default Zapping Batteries
I want to start making my own battery packs. If I buy a brick of unzapped & unmatched batteries, how do I zap and match them? I have a voltmeter.
Thanks,
jdcadman
jdcadman is offline
Old 01-09-2006, 07:43 PM
  #1377
zipp's Avatar
Originally Posted by wei25
hi
NO!!! that's one sure way to screw up the engine. use only nitro fuel available from your lhs, nothing else!
zipp is offline
Old 01-09-2006, 08:00 PM
  #1378
zipp's Avatar
hi jdcadman,
not sure about the zapping part. but the matching process involves discharging a fully charged cell at a fixed amp (eg 30, 35A) and measuring the average voltage for the discharge cycle. the cellls are then matched primarily according to their voltage, with other factors such as internal resistance and runtime considered also.
but to do all that u will need one of those sofisticated batt matching machines, and they're very expensive
a voltmeter won't work because it only measures the current voltage. what's important in cell matching is the discharge curve (ie voltage plotted against time) at a fixed amp draw. generally the higher the average voltage, the better the battery
cheers!
Thanks,
jdcadman
zipp is offline
Old 01-09-2006, 08:10 PM
  #1379
zipp's Avatar
found this article about battery zapping:
http://www.batteryuniversity.com/print-parttwo-48.htm
actually not that much about battery zapping itself, but some very interesting articles there, especially the memory effect one:
http://www.batteryuniversity.com/parttwo-33.htm
zipp is offline
Old 01-11-2006, 10:14 PM
  #1380
mkristanto's Avatar
Default sleeve resize
Hello,
Does anybody know where in singapore that able to do resize for 12 size engine?? Or sending to somewhere?
mkristanto is offline
