Go Back  R/C Tech Forums > International Forums > Singapore R/C Racers
Newbies Queries - Ask and you shall be answered! >
Like Tree1Likes
Old 12-08-2005, 05:11 AM
  #1351
zipp's Avatar
hey guys what time does s'wan model open tomorrow? or everyday of the week for that matter. thanks in advance
zipp is offline
Old 12-08-2005, 05:45 AM
  #1352
Default time.
hi zipp.12pm-8pm.sometime the store is closed for a short while.jus need to wait.cheers
traxxas is offline
Old 12-09-2005, 05:18 PM
  #1353
KickStart's Avatar
hi all...
i'm new to this hobby... so anyone can gimme suggestions on which 1/8 buggy to get? some of my frens told me HoBao is a good bargain... anyone got any comments?
KickStart is offline
Old 12-09-2005, 06:10 PM
  #1354
roadbuster's Avatar
it is closed on Sunday...fyi.
roadbuster is offline
Old 12-09-2005, 08:54 PM
  #1355
zipp's Avatar
thanks
zipp is offline
Old 12-11-2005, 02:28 AM
  #1356
csm87's Avatar
Originally Posted by csm87
hi singapore racers
i'm currently looking for a cheap, fast and efficient charger. i'm wondering if the Ansmann ACX2 Delta-Peak 2 Hr Charger is a good choice. its going for $28 at stargek. i'm wonder what its pros n cons are. currently charging 1700mah ansmann battery packs n GP3300 stick packs. plz post ur comments.
Thnx a lot, i appreciate it
if u're not sure abt which charger i'm talking abt, plz follow this link:
http://www.modelmaniacsonline.co.uk/...r&ManCode=ACX2
plz post ur comments thanks
csm87 is offline
Old 12-19-2005, 05:02 AM
  #1357
Default charger
hi..looking 4 a charger costing ard $100 to charge TX,RX batt , lead acid...what i know is to charge lead acid need ard 5amp ? saw the hitec cg330...izit gd?
bluemoon39 is offline
Old 12-19-2005, 08:57 PM
  #1358
Default 1/8 Buggy
Originally Posted by KickStart
hi all...
Im new too ..... just got a Hyper 7 .... Kind of a good car for beginner but too fast for me to handle. Options are below:
Sacker - $500 est
Hyper 7 - $650 est
X1CR - $700 est
Kyo 777 - $1k est
Kyo 7.5 - $800 est
Caster zx1 - $650 est
Decision is up to You....
james70 is offline
Old 12-26-2005, 06:19 AM
  #1359
kavo's Avatar
Default Help needed for APEXm+ (MU PLUS)
Hi,
I am using a APEXm+ (MU PLUS) charger, and I was wondering if it is normal for the wire connector head(from the charger) which is connecting to the transformer(the default blue color one) to be very hot while charging?
The connector head was so hot that it turned from white to yellow.
If I remembered correctly, previously it was not very hot..
Picture of connector
http://img.photobucket.com/albums/v5...ctor-black.jpg
http://www.apexhk.com/mup.html
kavo is offline
Old 12-27-2005, 10:19 AM
  #1360
Most probably the contacts have worn out/loosen over time, just replace with some good ones. Those are similar to tamiya connectors, and they don't last well.
Just Gundam is offline
Old 12-27-2005, 04:58 PM
  #1361
kavo's Avatar
Thank for the reply. Will try to change the connectors first and see how..
At first i thought was Apex V12 switching power suppy faulty.. Or maybe should i get a new transformer instead of using the default one from Apex?
kavo is offline
Old 12-31-2005, 04:20 AM
  #1362
orb_dharma's Avatar
Default Servo Problems Encountered
Hi, I'm new & need advice on problems I've encountered with my servos mounted on my 1/10 nitro car. The problem is that the servo flickers when I'm running it making it run inconsistently. I don't suspect crossing of channels as I'm normally playing alone with fresh batteries. I've so far changed two new servos for the trottle/brake levers but still encounter the same problem. Can the pros out there advice me on the likely causes for this & how I can rectify the problem. Thanxs
orb_dharma is offline
Old 12-31-2005, 06:35 AM
  #1363
E.T.'s Avatar
You mean the trottle servo Glitches during running?? What kinda batteries u use? NiMh?? Checked & tidy up the cable linking to the rx with a cable tie, it could help.
E.T. is offline
Old 12-31-2005, 01:56 PM
  #1364
orb_dharma's Avatar
Default Servo Glitches
Yup that's what exactly happens when I'm running it.
Batteries used: Sanyo 2300 NiMh / GP 6v Hump Pack
AM 27Mhz receiver / transmitter
Cables seem to be tidy
What else should I be looking out for? Help......Help
Old 12-31-2005, 02:23 PM
  #1365
zaRt's Avatar
hey not only u on gp car....i oso on ep car does happen...even on full charge...usuali happen wif my servo...i even put extra batts for my receiver
zaRt is offline
