Go Back  R/C Tech Forums > International Forums > Singapore R/C Racers
Newbies Queries - Ask and you shall be answered! >
Like Tree1Likes
Old 07-21-2005, 04:57 AM
  #1201
Nipple's Avatar
Originally Posted by firegarden777
What is Magic Cleaner? I am getting sick of dirty cars!!! Hehe. BTW were you the one in Tai Sing today who told me to mix grease with 10000WT oil for my buggy diff???
Yes, that's me.....so does it works for you?
Magic Cleaner is just a household cleaning solution, can get it at all minimarts and supermarket. The Green colour ones works great.
Nipple is offline
Old 07-21-2005, 05:30 AM
  #1202
firegarden777's Avatar
Dunno man...I put the stuff in the diff yesterday but no time to try. Seems that Simple Green cuts the grease better from what I hear. The other day I saw that one of the buggies in Tai Sing had all it's electronics and center diff removed and it was spotless. The rest of the stuff were in some bucket and not cleaned yet. So you just splash the chassis with water and Magic Cleaner then air dry??? I scared rust.
firegarden777 is offline
Old 07-21-2005, 06:17 AM
  #1203
Nipple's Avatar
No, first spray magic cleaner, leave it for about 15mins, then you spray it with water. Next I use compressed air to dry it, and lastly spray WD40 or any spray oil on the metal parts to prevent rust, Armorall on the plastic parts .
Nipple is offline
Old 07-23-2005, 10:15 PM
  #1204
xax
Hi guys need some of your advice. Just changed a new flywheel but then clutch bell will bind on the clutch if i tightened the screw unless i loosen a little else clutch bell will not be able to turn freely.So should i leave it or add washer inside the cluthbell.Thanks.
xax is offline
Old 07-26-2005, 12:12 AM
  #1205
kavo's Avatar
Default ESC Current capacity (FET rating: Forward:90A reverse:45A)
Is is the higher current for forward the better?
kavo is offline
Old 07-26-2005, 12:35 AM
  #1206
Piyo Piyo's Avatar
Add some shims between them. Once you got it spin freely, then your problem is solved.
Piyo Piyo is offline
Old 07-27-2005, 09:21 AM
  #1207
Eh I use hairdryer can or not? Seriously.
Old 07-27-2005, 09:47 AM
  #1208
Nipple's Avatar
Seriously, I never though of using hairdryer before. But I think it's a great idea, and I think it's better to use those blower (can select with or without heating). Hmmmmm........I'll go buy one tommorrow.
Nipple is offline
Old 07-27-2005, 10:18 AM
  #1209
Hey the Magic Cleaner works great!!! I was a bit scared that it would eat into the plastic but seems ok. Used the hairdryer without any problems. And sprayed with a good dose of WD40. Now ready for the weekend.
Old 07-28-2005, 01:36 AM
  #1210
Does anyone know where i can get mamba ESC in Singapore? I want to use it in my RC18t. Or anyone selling a mamba esc25 cm2068?
liquidsky is offline
Old 07-28-2005, 01:57 AM
  #1211
Got mine from here:
http://www.b-p-p.com/products.php?cat=14
BTW you want a Mini-t rolling chassis for cheap?
Old 07-28-2005, 10:54 AM
  #1212
hi guys.. i'm new here and i want to try out playing the RC kites.. those wif tons of LEDs.. may i know wat controller i would need to do so??
i dun wish to get it 1st hand.. due to the high price..
any to recommend?
something 4 ch and programmable? is this all i need besides the kite itself
gabriel06 is offline
Old 08-03-2005, 09:31 AM
  #1213
ART2's Avatar
Hi guys, got a question to ask "again"
Can I connect a 6V lead acid batt to an EP motor? Will it damage the motor? I'm asking because I'm planning to use the lead acid batt to power motor lathe.
ART2 is offline
Old 08-04-2005, 01:20 AM
  #1214
nixaad's Avatar
Haven't try, but dc Chargers yes. for motor prolly can, check the amp output for the acid batt.
nixaad is offline
Old 08-04-2005, 05:38 AM
  #1215
Nipple's Avatar
Bro, you mean can use 6v leadacid batt to power a dc charger or dc charger can be used to power a lathe motor? and wat's a motor prolly??
Nipple is offline
