Go Back  R/C Tech Forums > International Forums > Singapore R/C Racers
Newbies Queries - Ask and you shall be answered! >
Like Tree1Likes
Old 10-20-2014, 07:39 PM
  #4561
gabc's Avatar
Trader Rating: 15 (100%+)
Hi delio, I believe you'll find yourself at home at the DIOT track. Cheers! :-)
gabc is offline
Old 10-20-2014, 11:19 PM
  #4562
Anyone know where can i go to get my esc wires extended?
jason1980 is offline
Old 10-21-2014, 12:52 AM
  #4563
I heard of a veteran who told me to get from hardware store .You can try going to Kelantan Lane which is near to Sim Lim tower, there are a lot of hardware store over there. You can try your luck there.
Albertsg is offline
Old 10-21-2014, 08:30 AM
  #4564
Hi gabc. Thanks!! But one quick question. U mean i can run my 1/8 truck there? Nobody mind??
delio is offline
Old 10-22-2014, 05:05 PM
  #4565
gabc's Avatar
Yes you're right! But currently the track is under maintenance. Please refer to the DIOT forum:
http://www.rctech.net/forum/singapor...ack-b-723.html
gabc is offline
Old 10-23-2014, 06:20 PM
  #4566
Thanks gabc!!
delio is offline
Old 10-25-2014, 12:14 AM
  #4567
Hi, I'm a newbie here, can you just what electric car to be use or buy to someone like me as a newbie or do you know second hand ready to run car with cheap price that can be use for practice only thanks for your response
meptorio is offline
Old 10-28-2014, 10:50 PM
  #4568
gabc's Avatar
The pleasure is mine Delio!
Hey meptorio, do check out the Sg mkt place:
http://www.rctech.net/forum/singapore-sale-trade-148/
Sometimes you'll find really good deals. What type of car do you like? Then we can recommend. Cheers!
gabc is offline
Old 11-08-2014, 05:24 AM
  #4569
Default ........
twentyfour is offline
Old 11-11-2014, 07:23 AM
  #4570
Hi guys,
Any idea where can i get a 5mm size shaft 48pitch pinion here in singapore? Planning to buy a 21t pinion for my sct project as my motor has a 5mm shaft size. Thanks.
japong is offline
Old 12-15-2014, 05:54 PM
  #4571
Default No power in Thunder tiger mt4 G3
Hello racers
Need your help
there seems to be no power at all to the wheels
I have changed the central diff with new one and the wheel rotates without any issues when not on ground but as soon as it is on ground it does not go forward
Please help Thanks
as i cannot put in the url please search MOV 1467 in you tube.
anandpal is offline
Old 12-16-2014, 09:54 PM
  #4572
Originally Posted by anandpal
Hello racers
Need your help
Please help Thanks
Hi bro,
Saw your video. Check your center diff again as powers are not being transferred to both front and rear diff.
1. Checked your pinion gear as you may forgot to tighten it up when you did the maintenance. Put some thread lock.
2. Check your center diff pins are set and place nicely and not broken.
When you say you changed. Did you change the whole diff? What happen to your old diff? Broke the gears or pins?
japong is offline
Old 12-23-2014, 10:47 PM
  #4573
Originally Posted by japong
Hi bro,
thanks Bro for your time and reply.
Well after changing the centre front and rare diff the problem still persisted
How stupid can i be 4 days i spent on this only to find out that one of the drive shaft connected to the wheel had a pin missing,I put in the pin and it was working fine.
Upon research i found that its a safety feature,so even if one of the wheel looses power the remaining wheel will loose power.
Thanks for your help again
anandpal is offline
Old 01-02-2015, 09:04 AM
  #4574
Hi all, was doing some spring cleaning at home n found my long lost Hobao Hyper 7.....can anyone help me recommend me a shop that can do service on my hyper 7....
wavedid is offline
Old 01-06-2015, 05:42 AM
  #4575
skittles's Avatar
Default Help needed for motor..
Hi guys..anyone here have experience with the SKYRC ares pro 8.5t?
skittles is offline
