Go Back  R/C Tech Forums > International Forums > Singapore R/C Racers
Newbies Queries - Ask and you shall be answered! >
Like Tree1Likes
Old 07-02-2003, 08:21 PM
  #31
vones's Avatar
Originally posted by F&K
Hi there,
I am breaking in my new RB12T engine pretty soon. Just whether how many % of nitro should I use and which brand of fuel should I use that can give me both performance & protection!
u can just use the fuel tat u regulaly use just set it rich will do
vones is offline
Old 07-02-2003, 08:28 PM
  #32
NomeXX's Avatar
Location: Indonesia sometimes, Singapore sometimes, Mars sometimes, Venus sometimes...but home is where I wanna be
Hi there,
....the same brand & %nitro that you are going to eventually use
NomeXX is offline
Old 07-02-2003, 08:32 PM
  #33
F&K
F&K's Avatar
Tks NomeXX & vones for your feedback! Anyway what brand of fuel you guys are using? I like to have some recommendation!
F&K is offline
Old 07-02-2003, 08:43 PM
  #34
NomeXX's Avatar
Hi F&K,
Dun mention it Actually all fuel are about the same lah, just check-out what most people use and you won't go wrong
But make sure you stay clear of heli or plane fuel lorr
NomeXX is offline
Old 07-03-2003, 07:44 PM
  #35
vones's Avatar
Blue Thunder 25%.....I find it has a bit more lubrications(caster oil) compared to other brands.........performance wise don't c much difference frm other brands as well...
vones is offline
Old 07-08-2003, 08:29 AM
  #36
Airtronics M8
Hi guys,
I have a newbie question.
Im planning to buy an Airtronics M8 controller only.
I only have a stock servo that comes with my V-ONE S car kit.
And I have an AM receiver.
Will my Airtronics is compatible with my receiver and servos.
Thanks!!!
mediocrity is offline
Old 07-08-2003, 02:41 PM
  #37
Smile
Hi,
if u already got a am rx,than u need to know the freq 27mHz or 40mHz.
Than u can look for the M8 that suit ur rx.
Just my 2cents.
wolfman is offline
Old 07-08-2003, 06:01 PM
  #38
alana07's Avatar
Trader Rating: 53 (100%+)
Default Re: Airtronics M8
Originally posted by mediocrity
Hi guys,
Thanks!!!
hi fren,
yr AM receiver wont work with the M8 because original M8 operates on FM fequency. if you are to get the M8, you'll need the FM receiver or get the AM module for M8 which is available ONLY in 27mhz. for gas cars, its better to use FM system to operate them. the servo will work in all systems. hope this helps.
alana07 is offline
Old 07-08-2003, 06:17 PM
  #39
hellangel's Avatar
the M8 AM module ONLY works wif the mini-Z... it doesn't work wif normal sanwa AM receivers... i tested before already...
hellangel is offline
Old 07-08-2003, 06:22 PM
  #40
Vinyard's Avatar
other then that it does leaves a blue streak on the engines..
quite annoying
Vinyard is offline
Old 07-11-2003, 10:21 PM
  #41
Default Airtronics M8
Thanks guys!
So what servo should i buy for my steering and throttle so that i can make full use of my M8 controller?
Do i need to buy a digital servo? I just bought a Futaba 9402 hi-speed servo.
Thanks in advance.
Old 07-11-2003, 10:32 PM
  #42
by the way im running a v-one s.
Old 07-13-2003, 05:35 AM
  #43
alana07's Avatar
Thanks guys!
Thanks in advance.
hi fren,
the futaba 9402 servo is fine, in fact i'm using 2 in my v1rr
alana07 is offline
Old 07-16-2003, 09:02 AM
  #44
Default Re: Re: Airtronics M8
Originally posted by alana07
hi fren,
Thanks fren!
Old 07-22-2003, 05:34 PM
  #45
Default ESC
Hi,
Just got myself a Tamiya electric, was happily building away when I realised there's no space for a msc and second servo as space's pretty tight and there's no mounting holes in the upper deck. The upper deck's graphite, so I suppose drilling holes is definitely out.
May I know other than the "big" Sanwa esc which cld be had for ard $60, is there any other cheapo esc avail in S'pore? I need only something that cld take me to 19 turns.
Tronky is offline
