Go Back  R/C Tech Forums > International Forums > Singapore R/C Racers
Newbies Queries - Ask and you shall be answered! >
Like Tree1Likes
Old 01-28-2010, 12:23 PM
  #3856
Default Break in engine
hi guys,
how do we know if we have successfully achieved in break in engine?
what are the 'symptoms'? izit the idling fluctuates by itself during break in after a few tanks running?
thx
donnod is offline
Old 01-28-2010, 06:18 PM
  #3857
roychan69's Avatar
Originally Posted by donnod
hi guys,
thx
When your engine starts to gain more power; due to piston and sleeve broken in, you can lean down a little bit by bit to achieve peak performance.
Fluctuates as in factory settings...? It's either the LSN set too rich.
Get a friend who's good in tuning glow engine to help you.
roychan69 is offline
Old 01-28-2010, 07:18 PM
  #3858
rcfoxhound's Avatar
Trader Rating: 14 (100%+)
What after run oil is safe for engines with crank putty ie speed or jx21 .Thanks
rcfoxhound is offline
Old 01-28-2010, 07:47 PM
  #3859
roychan69's Avatar
A good quality after-run oil will do; they'll not deteriorate the putty.
Those putty is solvent and chemical proof.
Some don't even put as their nitro used contained enough mixture of castor oil; just make sure you burn it completely to prevent any gumming inside the engine due to unburnt fuel.
- Run it dry, and try to crank start it WITH the glow heater (no nitro in the fuel tank!) the engine will seems want to start or started for a few seconds, do this a few times and any fuel left in the fuel line and inside the engine will be burnt completely.
- Do not crank too many times, as that'll burnt the castor oil as well; which you want it to remained in the engine for rust prevention.
Old 02-01-2010, 09:10 AM
  #3860
peekarwe's Avatar
I actually have played this before and raced before but it's been a while. Trying to get back into the hobby now. I got an on road 1/10 gp car and just set everything up and realized I forgot quite a bit. I'm sorta running it in now. But the chassis seems to be heating up quite a bit. I looked at it, and I tried to push the car forward. It's free wheeling. But when I pulled it back, it sorts of jam up and locks up completely. Did I fix something wrong? I'm running a front one way if that matters, with a two speed gear box.
Further to the above, I must add that I bought the engine used. I am not sure if the needle settings have changed from factory settings but it's not that easy to start. I am thinking I should revert to factory settings but have no idea what they are. A quick check on the internet and google didn't turn up factory results, just some recommended user settings. Any idea? It's an OS TZ-12 5 port turbo.
The manual states that as long as the metering needle and LSN is flushed with the carb body, it should be fine... but I'm just not sure if I am accurate in determining that it's flushed.
peekarwe is offline
Old 02-02-2010, 02:51 AM
  #3861
roychan69's Avatar
Get someone who is good in tuning glow engine to help you tune at the track.
Old 02-02-2010, 07:21 AM
  #3862
james wong's Avatar
Default DualSky Brushless motor
Hi all,
I am looking for a DualSky Brushless motor,
Any 1 can tell me which and where can get the purchase either online or any hobby shop.
great thanks.
james.
james wong is offline
Old 02-03-2010, 09:07 PM
  #3863
Default Brushless motor!
Hi all,
can anyone teach me
1) how to calculate how many T is the motor?
Ex : 4300KV = how many T.
2) does brushless motor 5.5T = brush motor 5.5T?
hope someone can enlighten me.
thanks.
wolfman is offline
Old 02-04-2010, 03:08 AM
  #3864
adrictan's Avatar
Originally Posted by wolfman
Hi all,
can anyone teach me
thanks.
Can try this for a guide:
http://www.farmershobbyshop.com/inde...d=751&catid=16
http://www.rctech.net/forum/electric...onversion.html
adrictan is offline
Old 02-04-2010, 06:35 AM
  #3865
coldman28's Avatar
Default Drifting Tyres for my old super ten
By any chance is there any shop in SG that i can get DRIFTING TYRES for my old Kyosho Super Ten?
Any info would be great ........
Thank in Advance.
coldman28 is offline
Old 02-06-2010, 07:08 AM
  #3866
thanks adrictan,
like that than it all depends on the brand of the motor liao.
wolfman is offline
Old 02-10-2010, 05:48 AM
  #3867
mokbam's Avatar
Talking newbie
halo all im newbie in playing rc hope to more info here....
mokbam is offline
Old 02-11-2010, 04:46 AM
  #3868
SeYPeT's Avatar
Default HB and HPI kits
Hey there
Askin about where can i get HB TC-D kits here?? Hobby shop name and mayB address could be useful..
SeYPeT is offline
Old 02-11-2010, 04:51 AM
  #3869
roychan69's Avatar
Originally Posted by SeYPeT
Hey there
754, North Bridge Road, Singapore 198722. Tel: 6291 2633
Mon to Sat: 9.00am to 5.30pm, Close on Sunday & public holiday
www.taising.com/eng email:[email protected] email:[email protected]
hpiracing/Hotbodies/AtsushiHara/Nosram/Sanwa/Speed Passion
Old 02-13-2010, 06:00 PM
  #3870
Default looking for a tamiya tt01
i am looking forward to anyone that want to sell a tamiya tt01 drift rc ???
khuzaimy is offline
