Go Back  R/C Tech Forums > International Forums > Singapore R/C Racers
Newbies Queries - Ask and you shall be answered! >
Like Tree1Likes
Old 12-23-2009, 06:33 PM
  #3826
roychan69's Avatar
Originally Posted by harry5347
OK, noted. Tks enlighten
Xiexie
You're welcome.
roychan69 is offline
Old 12-25-2009, 09:14 PM
  #3827
Default GS Racing Spring colour code
Hi I have a big bore shock for GS. Not sure what is the hardness for the springs.
Yellow
Red
Blue
What is the oil weight, diff oil and spring colour you use for turf city with a GS CL1a?
somethree is offline
Old 12-25-2009, 09:31 PM
  #3828
roychan69's Avatar
Yellow
Red
Blue
The best person to ask is Ah Leng.
Old 12-30-2009, 09:28 AM
  #3829
Toh WL's Avatar
Yellow
Red
Blue
You can ask the GS distributor below also.
http://www.rctech.net/forum/malaysia...-buggy-40.html
Toh WL is offline
Old 01-02-2010, 06:09 AM
  #3830
roychan69's Avatar
Yellow
Red
Blue
Springs stiffness based on colour; normally it is:
White - Hard (Hardest)
Blue - Medium
Yellow - Medium Soft
Red - Soft (Softest)
As for shock oil; 40/45 front and 30/35 rear should be good as it's rather bumpy at Turf.
Diff oil; Front 7000, Central 10000, Rear 3000 should be good.
That will give you good turning-in for tight track.
It all depends on your driving style, and most importantly, your hand...
Old 01-15-2010, 02:09 AM
  #3831
Default need help with break in nitro engine
hi guys, izit normal for an engine during break in to revs up suddenly? my engine does that for the first half tank den back to normal idling.....izit my setting or izit always like that...is that normal? if its not, what do i need to do exactly?
donnod is offline
Old 01-15-2010, 02:15 AM
  #3832
roychan69's Avatar
No, it should not be as what you mentioned.
It's either it's set too rich (factory setting) that you could hardly make your truck move or at all. It will not rev high for the first half tank and back to normal idling.
Old 01-15-2010, 11:55 PM
  #3833
harry5347's Avatar
Default Having problem bind DX3R & SR3001
Hi guys, having problem to bind DX3R with SR3001.
This SR3001 is DSM, do not have bind plug, it's using press button type, im suspecting DX3R can only bind with DSM2. Anyone can confirm this?
Tks
harry5347 is offline
Old 01-16-2010, 01:29 AM
  #3834
Silvialite's Avatar
Tks
Not true. I ever bind a DSM receiver to a DX3R
Silvialite is offline
Old 01-16-2010, 02:47 PM
  #3835
thnks bro...so as ur saying,its ok if i adjust my high speed needle or idle setting for the first time break in?wat i mean is if my engine revs up high, i adjust the hsn..and if the idle is high, i adjust the idle needle..izit so?
donnod is offline
Old 01-17-2010, 03:04 AM
  #3836
Default HPI Cyclone D4 WCE buggy ESC / Motor / Battery recommendations
Hi hi. Just bought a new buggy. New to modern electronics. Used to play with CAT (electric) and Hobao (nitro) buggy and running on KoPropo EX5 during my secondary school days 19 years back.
Cannot find any pointers online for these areas. Very confusing. Can anyone point me in the correct directions? Just wish to run my buggy at the Bottle Tree track. I am currently into planes and wish to venture back to buggy again.
Thank you very much in advance.
leowster is offline
Old 01-17-2010, 07:11 AM
  #3837
roychan69's Avatar
If the revs is so high that it'll engage the clutch and moves, adjust the IDLE SCREW - Clockwise to tune High, Anti Clockwise to tune Low.
You can lean (a little) to your LSN, in order to get it going without stalling due to load up (nitro fuel load up).
Don't adjust the HSN yet till you've ran at least 6 - 8 tanks.
Old 01-17-2010, 02:58 PM
  #3838
Default Newbie in dire need of help
Hey guys, ive been reading this HUGE forum, and i really really like it. As i am writting in this thread.
I luckily found a Tamiya TT-01E converted to TT-01D with a castle brushless motor 4.6kv and Castle ESC, also with a futaba Remote and reciver 2.4ghz.
I am EXTREMLY new to this industry, ad LOVE it so far.
The reason why i wanted this chassi from the research that I did, is because I just wanna drift
The Electric rc car was bought used, and did not really come with alot of manuals
How could i get manuals, and more detailed information about what i have and how to operate it.
I accidently changed somehting on the remote, and now i have no steering.
I think i Shorted the Servo because it lights up green, beeps. and then turns off. Before it didnt turn off the ESC, but now it shuts that off as well.
HELP!
dredrift is offline
Old 01-17-2010, 06:34 PM
  #3839
roychan69's Avatar
HELP!
Jie Ming (Stanley) can help you:
Stargek Private Limited
178 Paya Lebar Rd
Unit #01-03
Singapore 409030
Tel : +65 6746 2168 Facsimile : +65 6746 4678
Email : [email protected]
Operating Hours : 10.00am - 6.00pm(Mon - Sat)
10.00am - 3.00pm(Sun) except public holidays.
Old 01-23-2010, 10:02 PM
  #3840
MajorTom's Avatar
Default Squeaky steering servo - old bandit
I've a 10-year old Traxxas Bandit I bought off of craigslist. The steering servo made some god-awful noise when steering, an "eek" or squeak sound. I replaced it with the other servo from the car, same part number, that was available when I replaced the mechanical speed control with a new XL-5 ESC.
The other servo also "eeks." The Traxxas part is 2018. I don't think this servo type has ball bearings...?
Is this thing just going to be noisy, or should I consider the servo nearly dead and in need of an upgrade? It seems to work fairly well, just noisy...
Thanks in advance.
MajorTom is offline
