Go Back  R/C Tech Forums > International Forums > Singapore R/C Racers
Newbies Queries - Ask and you shall be answered! >
Like Tree1Likes
Old 12-07-2009, 04:57 PM
  #3811
Nov
Nov's Avatar
Originally Posted by Ivan Hng
EP bros out there, I need some advice.
I need to extend the wires from my ESC to reach the motor. (SC10)
The stock wires came as 6 inches. To place the ESC and motor into the truck, i need around 8-9 inches.
1) Should I connect directly from ESC to motor?
2) If not, what kind of connector should I use.
3) The stock wires that came with my ESC is 12 AWG. Is it enough?
(100 amp 5200kv on 2S lipos)
4) If I don't connect the sensor wire from ESC to motor, what will happen?
Do kindly leave your comments. I would really need some help here.
Thanks in advance!
Cheers!
1) If you change your motor often and you hate soldering, then you should not solder direct to the ESC...
2) You can use those mini-banana plugs...I think its 3.5mm size...Its shorter and slightly smaller in diameter compared to the banana plugs we use on batteries...
3) 12AWG is thick enough...Your motor will not draw 100A continuously...So I dun think there's any issues on wire gauge...
4) If your ESC supports sensorless mode, it will run in sensorless...But if it doesn't, then it just doesn't move...
Nov is offline
Old 12-07-2009, 05:07 PM
  #3812
Ivan Hng's Avatar
2) You can use those mini-banana plugs..I think its 3.5mm size...Its shorter and slightly smaller in diameter compared to the banana plugs we use on batteries...
Noted! Thanks for the advice!
Ivan Hng is offline
Old 12-12-2009, 05:22 AM
  #3813
hi, noobie here... hijack a bit...
May I know how much does the TT01D (drift series) usually cost.
Wanted to try out this new hobbies
hansenhon is offline
Old 12-13-2009, 03:18 AM
  #3814
roychan69's Avatar
Call them...
Contact Information:
Stargek Pte Ltd
178 Paya Lebar Rd
Unit #01-03
Singapore 409030
[email protected]
Telephone : (65) 6746 2168
Facsimile : (65) 6746 4678
roychan69 is offline
Old 12-20-2009, 11:48 PM
  #3815
opficon's Avatar
guys, im from indonesia.. is there any local hobby shop who had some great year end/christmas sale? and, could you guys please help me in where hobby shop that i could fine any speed passion products? thanks..
opficon is offline
Old 12-21-2009, 02:27 AM
  #3816
roychan69's Avatar
So, I should call you Fast Crashed instead...
They are having a 10% discount for all store items now, and they have the brand you want...
Tai Sing
754, North Bridge Road, Singapore 198722. Tel: 6291 2633
Mon to Sat: 9.00am to 5.30pm, Close on Sunday & public holiday
www.taising.com/eng email:[email protected] email:[email protected]
hpiracing/Hotbodies/AtsushiHara/Nosram/Sanwa/Speed Passion
Old 12-21-2009, 04:34 PM
  #3817
opficon's Avatar
Tai Sing
thanks alot roychan69.. may i ask another question? which hobbyshop who sell 3racing products? big thanks..
opficon is offline
Old 12-22-2009, 06:00 PM
  #3818
roychan69's Avatar
Sorry late reply as I was busy these few days...
It's hop-up parts for Tamiya...?
Try Atalon and Just Hobby at Turf City.
Address: 200 Turf Club Rd #01-48, Singapore 287994
Operating hour: Mon to Fri :1200~2100hrs, Sat-Sun : 1100~2100hrs
Tel: 6464 8233 Mobile: 8418 9989 Email: [email protected]
Old 12-23-2009, 02:17 AM
  #3819
opficon's Avatar
it's for hotbodies actually.. okay, thanks alot btw roychan69 for the info..
opficon is offline
Old 12-23-2009, 02:20 AM
  #3820
roychan69's Avatar
Tai Sing then?
Old 12-23-2009, 02:47 AM
  #3821
harry5347's Avatar
Default Dented pipe & manifold
Hi guys, i had a bad side impact, both my pipe & manifold are dented, like to check with you guys,
1. how do i ''pull out'' the exhaust tip & spring lock tip?
2. how do i bent the manifold back to it's position?
Will heat treatment helps? I've tried to force it, but it seems seems lagi chalat
TIA
harry5347 is offline
Old 12-23-2009, 03:20 AM
  #3822
roychan69's Avatar
TIA
Use a screw driver and insert it into your exhaust tip, and bent it back to shape, same goes to your manifold. Wrap your screw driver tip with a little piece of cloth or foam.
You don't need to heat them up.
As for the dented exhaust itself, put water into the pipe and seal it with plastic bag with many rubber bands to make it 'water tight', put it in a freezer, as the carbon dioxide 'escape' from the water, it'll force and bulged the exhaust.
Watch the freeze timing though, you don't want a ballooned exhaust.
Old 12-23-2009, 06:42 AM
  #3823
harry5347's Avatar
Hi bro, you mean fill the pipe with water, seal tight the outlet ya? freeze till form ice or need to check condition while progress?
paiseh, noob here
kum sia
Old 12-23-2009, 04:30 PM
  #3824
roychan69's Avatar
paiseh, noob here
kum sia
Yes.
Seal the stinger as well; that's how it'll keep the water in, right?
You'll only need to check it when it's about to form into ice.
Old 12-23-2009, 05:43 PM
  #3825
harry5347's Avatar
OK, noted. Tks enlighten
Xiexie
Yes.
