Go Back  R/C Tech Forums > International Forums > Singapore R/C Racers
Newbies Queries - Ask and you shall be answered! >
Like Tree1Likes
Old 10-29-2009, 12:52 AM
  #3706
roychan69's Avatar
Originally Posted by donnod
hi guys,
anyone knows the correct procedure for breaking in engine?
guys pls advice...currently i'm using rb tj9......
thx
It's better you check on the U Tube 'RC - How to broke in new engine'...
Better still; get an experienced person who is good at nitro engines, together to help you at the track.
roychan69 is offline
Old 10-30-2009, 12:54 AM
  #3707
alantan_74's Avatar
Originally Posted by roychan69
Hello Alan.
1. Yes, you can weld back your pipe's stinger if it is bent or broke off.
Make sure you only use aluminum filler rod to MIG (Metal Inert Gas - Argon) weld.
2. Possible, just change the shocks to a shorter ones; to lower the CG (Centre of Gravity) and get a set of Truggy tires instead of using those big monster tires.
Hope it helps.
1) Hi,do you know anyplace that can weld or..
2) juz change e shock n tire only? shock tower and arm dun need har??
Tks a million bros..
alantan_74 is offline
Old 10-30-2009, 01:37 AM
  #3708
roychan69's Avatar
1. Any smaller companies doing engineering works; and if they have TIG weldings (Argon Weld) they can do the job. Try places like Eunos Industrial Park etc..
2. Shock Tower no need to change. So long you've changed to a shorter shocks, or the advice below, the CG is lowered.
*Cheaper alternative: Replace the shock shafts to shorter ones, or you can cut a section of fuel tubing about 0.5 - 1" and slot it in your shock shaft (inside the shock, not outside) to achieve a so call 'Droop'. It's basically like replacing with a shorter shock shaft.
So... You owe me 2 million now...??
Old 10-31-2009, 09:10 AM
  #3709
ben_xraynt1's Avatar
hi guys,
thx
on road engine or off road.
just head down to pa track on sunday , and im sure guys there will gladly give u a big helping hand bro.
roy is right u could check the youtube for some info on the how.....
cheers and enjoy the hobby......
ben_xraynt1 is offline
Old 10-31-2009, 09:19 AM
  #3710
hi guys,
currently i'm looking for a gp 1/10 car with less hop ups and less maintainance....my budget is around 800.which car falls under my criteria? izit serpent, mugen, edam, nt1 or g4rs?
and also, what is tx and rx? (i'm a newbie by the way)
thnx
so wat kit have u bought?
800 incl kit, engine , tx , rx , starter box , glow starter , and electronics?
these are wat u need to get started bro.
coz dun think u can get all with that budget unless maybe those rtr gp kit....
Old 11-03-2009, 01:12 AM
  #3711
its on road......by the way i found this website on how to break in engine,it says {NEW SCHOOL METHOD}, it teaches u how to break in the new way...it seems that this method goes agaisnt the old skool method..bro plz check this site.....from ur experienced, does this werk?
donnod is offline
Old 11-03-2009, 01:18 AM
  #3712
i cant list down the add here as i'm new to this forum.....u can go to yahoo search engine and type how to break in rc engine and u look for NEW SCHOOL METHOD......
donnod is offline
Old 11-03-2009, 01:31 AM
  #3713
nope, actually 800 budget is only for the kit itself....by the way i bought serpent 733 and rb touring junior 9...not still 'reckiiing' on the electronics and tx and rx.bro,can advise me wat type of tx and rx and also electronics is worth buying....
currently wat car are u using? by the way where is pa track? izit the one at east coast?
donnod is offline
Old 11-04-2009, 12:28 AM
  #3714
alantan_74's Avatar
Default Servo for monster truck 1/8
Hi, Anyone can advice which n wat servo to use for monster 1/8.Must at least hw many KG..
Tks
Old 11-04-2009, 01:01 AM
  #3715
roychan69's Avatar
Tks
Use at least 16kg servo for your MT steering, i.e. Futaba 9351 or BLS352
I used BLS352 for my Savage X.
Old 11-04-2009, 02:03 AM
  #3716
adrictan's Avatar
Tks
If u have deep pockets, order in a JR High Torque servo. Z9100HVT or Z9100T. Backed by 3yrs warranty. I have a Z9100T on my truggy.
adrictan is offline
Old 11-04-2009, 06:18 AM
  #3717
roychan69's Avatar
It's a little expensive for him I believed; he should be... er... quite new to this hobby, use Futaba or Hitec (much cheaper and he can get the 24kg strength servo...)
Old 11-04-2009, 06:31 PM
  #3718
alantan_74's Avatar
Tks everyone..Notice someone selling Towerpro servo 14/15kg.. is it good enuff?
Old 11-04-2009, 06:56 PM
  #3719
roychan69's Avatar
Similar to Ace or Thunder Tiger; can be use since you're not racing.
Old 11-04-2009, 10:20 PM
  #3720
alantan_74's Avatar
Tks.. Think i will get that as long is gt e power to turn e sterring..
