Go Back  R/C Tech Forums > International Forums > Singapore R/C Racers
Newbies Queries - Ask and you shall be answered! >
Like Tree1Likes
Old 10-23-2009, 09:09 PM
  #3691
Default tuning engine
hi guys,
anyone knows the correct procedure for breaking in engine?
guys pls advice...currently i'm using rb tj9......
thx
donnod is offline
Old 10-24-2009, 01:51 AM
  #3692
Originally Posted by adrictan
Wht car r u using?
HPI Brama
scogencrosby is offline
Old 10-24-2009, 01:56 AM
  #3693
adrictan's Avatar
Originally Posted by scogencrosby
HPI Brama
Just make sure yr gear mesh is not too tight. If there's alot of grinding sound, it might be because of yr gears being too close together. Check for the gear wear as well.
adrictan is offline
Old 10-24-2009, 08:17 AM
  #3694
Originally Posted by HarryLeeWD
Can anybody recommend me a cheap 12v DC charger?
Need roughly 4 amps charge rate, and discharge function would be sweet as well.
Don't need lipo capability.
And anybody ever run 12vDC chargers off your car's cigarette lighter?
Thanks!
Go for muchmore!!!
bwtay is offline
Old 10-24-2009, 10:10 AM
  #3695
Default What batteries can sanwa m8 use?
What batteries can m8 use apart from the original battery? I dont have the original charger.
Sexytoy.com.sg is offline
Old 10-24-2009, 10:22 PM
  #3696
adrictan's Avatar
Can't u use normal AA alkaline batteries? If not, just get a normal DC charger.
adrictan is offline
Old 10-24-2009, 10:26 PM
  #3697
SuperEk4's Avatar
Trader Rating: 32 (100%+)
Lipo lah
SuperEk4 is offline
Old 10-24-2009, 10:27 PM
  #3698
Originally Posted by ongbenghui
Just to add, Kelantan Lane got a screw shop that is pretty friendly. And they sell US type 4-40 screws as well.
So, if you need screws and fastener, check out that place. I am sure, it is cheaper than more hobby shop.
Alternatively, you could try sungei road. Lots of good deals there too.
bwtay is offline
Old 10-24-2009, 10:58 PM
  #3699
Thanks!
Go for BOL Charger. Fits your description nicely.
Trust is offline
Old 10-25-2009, 11:51 AM
  #3700
Default I have a M8 but it does not seen to work.
I have a M8 but it does not seen to work. I notice the tx frequency is 40.75 whereas the Rx frequency is 40.875. Is it a matching crystal?
Old 10-26-2009, 09:21 AM
  #3701
Thinking of a no.
shaddowsiner is offline
Old 10-27-2009, 05:55 PM
  #3702
Default TT EB4 S3
Saw this 1/8 buggy at Rotor. It comes with .28 pull start engine and a 2.4ghz transmitter selling at 450sgd. Need some advise or feedback from anybody who's playing buggies. Thanks.
team magic is offline
Old 10-28-2009, 11:42 PM
  #3703
alantan_74's Avatar
Hi,
1) Does anyone know if the pipe tip break off is it poosible to weld or glue back?
2) Is it worth or poosible to tranform a monster truck to truggy and how should i go with it..
Tks a million....
alantan_74 is offline
Old 10-29-2009, 12:45 AM
  #3704
roychan69's Avatar
Originally Posted by alantan_74
Hi,
Tks a million....
Hello Alan.
1. Yes, you can weld back your pipe's stinger if it is bent or broke off.
Make sure you only use aluminum filler rod to MIG (Metal Inert Gas - Argon) weld.
2. Possible, just change the shocks to a shorter ones; to lower the CG (Centre of Gravity) and get a set of Truggy tires instead of using those big monster tires.
Hope it helps.
roychan69 is offline
Old 10-29-2009, 12:48 AM
  #3705
roychan69's Avatar
Can anyone advise me on the things i should do to make my gears and shaft run more smoothly? The gears and the shaft seems to be dry and are making cranking sounds when my car moves.
Use some black grease.
