Go Back  R/C Tech Forums > International Forums > Singapore R/C Racers
Newbies Queries - Ask and you shall be answered! >
Like Tree1Likes
Old 06-05-2009, 06:06 AM
  #3286
fadeaway's Avatar
Originally Posted by ben_xraynt1
bro i sand my shell before spray the paint and it works wor. crash also won't fall off man.
what grit of sand paper you use?
for those choosing paint (hardware shop type)
i prefer bosny or fox they produce finer spray droplets (quality same same)
use to like pylox now give up. their clear coat produce yellowish hue especially on white.
fadeaway is offline
Old 06-05-2009, 06:28 AM
  #3287
Anyone getting glitch on spektrum recievers(sr 3300T) with TEU-101BK esc?
tried 2 esc and both same problem. no other problems with other esc on that rx
HuFFy is offline
Old 06-05-2009, 07:35 AM
  #3288
andre lim's Avatar
Trader Rating: 58 (100%+)
Originally Posted by Ivan Hng
Eh, you like trying to spy every thread I post hor! Nbz, who spray your shell for your one har!
KNN, U spy me 1st lor!
andre lim is offline
Old 06-05-2009, 08:56 PM
  #3289
Ivan Hng's Avatar
Originally Posted by m33g0
wont the surface be blur or rough after sanding?
I doubt so. As you are spraying from the inside. The outside is covered with a layer of film. So by sanding, the paint 'bites' into the lexan.
I cannot find bosny paints around my area. Anyway, pylox paints have many hues and colours to choose from. including metallic ones to give it a shimmering look.
Ivan Hng is offline
Old 06-05-2009, 08:57 PM
  #3290
Ivan Hng's Avatar
KNN, O where got spy on you! I better get PPO (Personal Protection Order) liao!
Ivan Hng is offline
Old 06-05-2009, 08:58 PM
  #3291
Ivan Hng's Avatar
~Double post~
Ivan Hng is offline
Old 06-05-2009, 09:57 PM
  #3292
ben_xraynt1's Avatar
the 1st i did was blur the 2nd i done up was not too bad . ya it gets abit blur
[QUOTE=fadeaway;5900324]what grit of sand paper you use?
1000
Btw guys, you are into gp or ep?
im a gp driver.
ben_xraynt1 is offline
Old 06-05-2009, 10:24 PM
  #3293
Ivan Hng's Avatar
[QUOTE=ben_xraynt1;5903057]the 1st i did was blur the 2nd i done up was not too bad . ya it gets abit blur
1000
im a gp driver.
EP On-road and GP/EP Off-road.
I can see you are on-road driver right?
Ivan Hng is offline
Old 06-05-2009, 10:35 PM
  #3294
[QUOTE=Ivan Hng;5903125]
yup , u can see it in the pic bro....
so u go bottletree yishun?
Old 06-05-2009, 11:09 PM
  #3295
Ivan Hng's Avatar
I have been there, but not often.
Ivan Hng is offline
Old 06-06-2009, 04:41 AM
  #3296
[QUOTE=Ivan Hng;5903217]I have been there, but not often.[/QUOTE
Im usually at east coast pa whenever had the time
Old 06-06-2009, 06:54 AM
  #3297
Ivan Hng's Avatar
Currently, I'm finding time to make time to spend more time with my toys.. No chance to play due to work..
Ivan Hng is offline
Old 06-06-2009, 10:35 PM
  #3298
m33g0's Avatar
what about the outer surface ? from the view we view at our shell...will it be blurred and not shiny anymore ?
m33g0 is offline
Old 06-06-2009, 11:13 PM
  #3299
Ivan Hng's Avatar
You see, you sand the surface on the inside of the shell. Thus, the outside of the shell is not affected as there is a layer of film that protects the outside of the shell when you are sanding or spraying the paint.
You ONLY remove the layer of film AFTER you have finished applying the paint. So the OUTSIDE of the shell is still shiny and glossy. As the paint adheres to the lexan on the inside of the shell, the outside is not affected.
If you have sprayed a shell before, you will know what I mean. You have to try to understand.
Ivan Hng is offline
Old 06-06-2009, 11:18 PM
  #3300
Ivan Hng's Avatar
Taken from Proline's website.
What Youíll Need - Supplies
Dish soap
Clean cloth or paper towel
Fine steel wool, or SOS pad
High quality masking tape (3M)
Permanent marker
Straight and curved scissors
Sharp hobby knife
Pencil
Lexan compatible paint
Homemade wheelwell template
Window masks, Decal sheet, wing mounting hardware
Wash your body
To remove any residue left on the body after molding, you must wash it inside and out. Use warm soapy water in your sink, paying special attention to the tight curved areas and corners. Dry the body with a clean towel or hair dryer. It must be completely dry before you paint it.
Cut off the wing
If your body came with a wing or spoiler molded into the excess material, you must cut it off. Some wings are molded in the opposite direction of the body. If this is the case you must remove the protective film, and paint the reverse side.
Marking the Body Posts
If your body does not have mounting holes marked for your chassis you can mark them before you paint. Drop the body over your chassis, center it and use a permanent marker to mark the body posts. You can also mark the wheel wells. Touring car and On-Road bodies sometimes have no rear wheel well outlines, this give you freedom to make a perfect fit for your chassis. (Touring Car body shown)
Marking the Wheels
While your body is over the chassis, you can also mark the wheel wells if neccessary. Touring car and on-road bodies sometimes have no rear wheel well outlines, this give you freedom to make a perfect fit for your chassis. A great tip is to make a wheel well template, and use it to trace 4 identical wheel well shapes. They can be made from either scrap lexan, or cardboard.
Window Masks
Using the molded in window lines as a guide apply the window masks to the inside the body. Be sure to press down all the edges to keep paint from sneaking under. The masks keep the windows clear while you paint.
Step 1: Tape Stripes
This paint scheme is quite simple, and uses straight masking tape for the design. Make sure you use high quality masking tape, and press down all the edges. First mask off the color that you want to paint last.
Step 2: Continue Taping
Fill in the area you want to paint with your second color. I used blue and beige tape to show the separate paint sections. Painting from dark to light is ideal, so leave the darkest section clear, and paint this first.
Step 3: First Coat
Step 4: Finish First Coat, & remove mask
When your first color has completely dried, unmask the second section of the paint scheme. While removing the tape, watch that you donít remove any of the stripes accidentally.
Step 5: Paint 2nd color & remove msk
Again spray light coats and cover evenly. You can then back it with white or silver, but in my case I will use silver for the stripes, so no need to back it separately. When the paint has completely dried remove the taped stripes.
Step 6: Paint stripe
Now fill in the stripes with silver, and also back up the blue section in the middle, and on the bed.
Step 7: Window Trim
Painted window trim is very popular, and easy to create. When your final backup coat is dry, trace and trim around the inside of the window mask creating a border. Remove the borders from all the windows and spray with your favorite color.
Step 8: Flat Black Bed
Another option is a flat black tonneau cover or bedliner. With a sharp hobby knife cut the protective film around the bed, and peel it away. Spray the bed with hobby paint, or flat black enamel. The film will protect the rest of the body.
Step 9: Trim & test fit
Trim out your body using curved scissors for the wheel wells and straight scissors for the lower lines. Drill out your body post markings with either a Dremel tool or reamer. The protective film will help keep your body from getting scratched as you cut and drill.
Tip: For added durability it is recommended to sand all rough and sharp edges with a sanding drum or stone.
Step 10: Remove protective film & window masks
Peel back the protective film, and remove the window masks.
Step 11: Decal & Detail
Apply the decals included with the body, add extra details with a paint pen or Sharpie marker if you wish.
http://www.prolineracing.com/t-HowToTipsPaintingA.aspx
Ivan Hng is offline
