Go Back  R/C Tech Forums > International Forums > Singapore R/C Racers
Newbies Queries - Ask and you shall be answered! >
Like Tree1Likes
Old 05-25-2009, 05:54 AM
  #3241
wATERbOTTLE's Avatar
Originally Posted by Movi$tar
to each his own...just go for what u likes...
so their about the same
wATERbOTTLE is offline
Old 05-25-2009, 09:17 AM
  #3242
m33g0's Avatar
where can i get those cool stickers like vinlys or LABEL stickers(e.g HKS NOS RALLIART MUGEN ALL THOSE )THANKS !
m33g0 is offline
Old 05-26-2009, 07:27 AM
  #3243
Movi$tar's Avatar
help...my TT01 suddenly like jammed...can only moves bit by bit...
then the tamiya plug head both male n female plug n ESC is so hot...
anybody knows whats the problem ?
ESC spoil or ?
btw,im using stock tamiya ESC n servo n receiver n motor...
Movi$tar is offline
Old 05-26-2009, 07:33 AM
  #3244
Trader Rating: 14 (100%+)
ESC spoil or ?
most probably the tamiya plug is damaged. happens all the time. which is why most of the folks replaced the tamiya plugs to deans plugs.
if u keep using it, the tamiya plug will eventually melt.
psychophant is offline
Old 05-26-2009, 07:56 AM
  #3245
York's Avatar
Default Spoilt TRF dampers??
hey guys... i just bought a 2nd hand chassis that came with 4 TRF dampers...
i realised that the shaft is not pushing out after i change oil... im using the same matter to change oil for my own TRF dampers.
wad is the caused? nid to change wad? pls pm me or post
York is offline
Old 05-26-2009, 08:02 AM
  #3246
ben_xraynt1's Avatar
i realised that the shaft is not pushing out after i change oil... i did the same matter to my own TRF dampers.
not too sure if it works the same for ep, im a gp driver, u strip the damper and check the plate inside if the edge is smooth not , sometime uneven finish hinder the movement of the shaft . i had the same problem once, some guys told me the same and the problem is solve .
ben_xraynt1 is offline
Old 05-26-2009, 08:22 AM
  #3247
Movi$tar's Avatar
omg damnit, i just change all the plugs to tamiya plugs from deans !!!!!!
n each tamiya plugs cost $5 from StarG*k...!!!
wah lau eh...grrrrrrrrrrrrrrrrrrrrrrrr
Movi$tar is offline
Old 05-26-2009, 08:34 AM
  #3248
lol... that's a downgrade rather than an upgrade!!!!
Old 05-26-2009, 08:51 AM
  #3249
Movi$tar's Avatar
wah lau eh,dont say liao lah...
sian 1/2 already...
so the best is deans plug ?
if yes,tomorrow go buy n re-solder again liao....
:flam ing:
Movi$tar is offline
Old 05-26-2009, 07:45 PM
  #3250
adrictan's Avatar
Try to take everything out. Inspect the shock shaft and everything. What wt oil are u using? Clean everything before u change the oil.
adrictan is offline
Old 05-27-2009, 08:53 AM
  #3251
Default ESC Problem?
Noob here.
1. Why does my car reverse when I squeeze the throttle? My throttle setting is set to Normal. Now I have to set to Reverse so when I squeeze throttle it will go forward. Why?
2. How to reset Futaba MC330CR ESC? I suspect is this thingy causing the above.
Pls advise as I do not understand the manual of, Neutral, Throttle and Reverse.
Thanx bros.
Teva is offline
Old 05-27-2009, 06:54 PM
  #3252
Hi all, care to share wat's the widest offset rim a tamiya gtr r35 bodyshell can take?
_mit is offline
Old 05-27-2009, 07:34 PM
  #3253
Ivan Hng's Avatar
I tried using 9mm offset rear and 6mm offset front. No problems.
Ivan Hng is offline
Old 05-27-2009, 07:36 PM
  #3254
Ivan Hng's Avatar
Originally Posted by Teva
Noob here.
Thanx bros.
For the forward reverse thing, just reverse your throttle channel.
And i advise that you reset your ESC. Just follow the manual.
Ivan Hng is offline
Old 05-28-2009, 12:53 AM
  #3255
Movi$tar's Avatar
where to get the drift tyres that can make some sparks ?
whats the model n brand of it ?
Movi$tar is offline
