Go Back  R/C Tech Forums > International Forums > Singapore R/C Racers
Newbies Queries - Ask and you shall be answered! >
Like Tree1Likes
Old 04-29-2009, 11:11 PM
  #3106
Originally Posted by Ivan Hng
No prob bro. Good to know that you managed to get the tyres in. I got help last time when i started. So i guess its only the right thing to do to pass it on.. LOL.. Happy drifting!
still very noob in drift..always cannt drift slowly and nicely
any suggest or tips from u?
I saw ppl drift with low speed and entering cover with beautifull drift curve. any modification to the car i need to do or this just purely skill?
so far what i had done is lock the rear diff gear.
sprig is offline
Old 04-30-2009, 01:12 AM
  #3107
Nov
Nov's Avatar
If you think your car is too fast, you can try using lower grip tires or playing on less grippy surface...
Or else ask those people whom you saw...
Nov is offline
Old 04-30-2009, 01:48 AM
  #3108
Rohitx's Avatar
Try the PVC tires and see how u feel. Using tires which has strong grip will make ur car go fast. PVC is slippery hence u can have that smooth slow drift curve u mention. Hahah.
Rohitx is offline
Old 04-30-2009, 02:35 AM
  #3109
so it reli my skill...not my chassic setup
now i using T-drift, the drift curve is big...need more training.....
i hear if i mod my front to 'one way front' i can entering corner easily and with lower speed..is that true? how much is this "one way front" hop up?
sprig is offline
Old 04-30-2009, 06:39 AM
  #3110
Rohitx's Avatar
Well personally i have not tried the front one way. I heard its good for drifting n if you have a front one-way and you hit the brakes, the rear wheels stop, but the front wheels keep spinning.
Not too sure how much would it cost but i know Orchard Plaza (Winnie) has it.
Rohitx is offline
Old 04-30-2009, 06:25 PM
  #3111
lamboza's Avatar
Default newbie
Does any 1 has the problem of oversteer? the car kept spinning.. How to overcome it ? and also my car front left tires kept brushing against the shell causing the paint to fade.. any possible solutions ?
Cheers
lamboza is offline
Old 05-01-2009, 03:16 AM
  #3112
kaixxxx's Avatar
Cheers
regarding ur oversteer problem, wad kit are u using?
is it when u throttle it spins straight away or it is just oversteer problem?
if it is just oversteer problem, maybe u can change ur rear spring to soft or adjust ur ride height.
as for ur front tyre keep bushing against ur shell, maybe u can use a curve scissor to cut away the part where it hits ur wheel. OR adjust ur shell by moving it higher.
kaixxxx is offline
Old 05-01-2009, 06:35 AM
  #3113
lamboza's Avatar
the oversteer problem is solved however the tires are still brushing against the shell .. is not the side of the shellls but deeper inside..
[eg when turning right the top left tires will brush against the shell and cause a werid sound.. maybe is it the offset of the rims?
lamboza is offline
Old 05-01-2009, 06:41 AM
  #3114
Rohitx's Avatar
I would think its the wheel offset or the ride height problem here. Try using 0 offset rims or increase ur ride height in the body post.
Rohitx is offline
Old 05-01-2009, 07:13 AM
  #3115
lamboza's Avatar
Increase the height not nice alr. the rims are 3mm offset.. my LHS didn't mention that i have to offset any stuff..
Currently using E10 and 26mm rims. with Maxconcept hard tyres.
lamboza is offline
Old 05-01-2009, 09:26 AM
  #3116
Rohitx's Avatar
LHS will give u suggestions but its upto u what u WANT in thd end. In this case, use 24mm rims then.
Rohitx is offline
Old 05-01-2009, 09:40 PM
  #3117
Default Newbie
Hi people out there, i just bought a team magic model RTR G4 JR.It is my first car.Can anybody advise me on how should i take care of my car as well the pros and cons about it.Thanks!
maruthi is offline
Old 05-01-2009, 10:40 PM
  #3118
hi,im interested in getting a t15 charger,this charger does not have a balancer right?
rather than getting a t15 and a balancer(T6B?) is it more worth to get the T15 plus?
ruein is offline
Old 05-02-2009, 01:47 AM
  #3119
lamboza's Avatar
Hi , my friend have this lipo battery which is kind of bloated.. brand is Titanium velociti 5100 mah 28C .. if put on table and spin can reach up to 7 rounds.
shld he still keep this lipo? cos my lipo doesn't have this bloated case and won't spin.
lamboza is offline
Old 05-02-2009, 02:53 AM
  #3120
Default Signs of low batt?
hi wad are the signs of low batt? Mine is like car jerking. and why my 1500mah batt fully charged cant even play like for 2mins. using tamiya plug.
tiffanydunk is offline
