Go Back  R/C Tech Forums > International Forums > Singapore R/C Racers
Newbies Queries - Ask and you shall be answered! >
Like Tree1Likes
Old 04-19-2009, 09:38 PM
  #3076
Originally Posted by Silvialite
IMHO, it should not be a problem to use any receivers with both digital and analog servos. The MX-3 receiver can take both digital and analog servos.
Just my $0.02. Kindly correct me if I'm mistaken.
Thanks,
Then can a HRSS receiver use a anologue servos?
great_scott is offline
Old 04-19-2009, 10:50 PM
  #3077
lamboza's Avatar
Originally Posted by grategenin
Look in your manual or read the description. And when your motor starts losing power fast, not preforming normally.
Motor starts losing power meaning ? cos after like 30-45 mins of run time,
the motor area would be hot and the motor too.
Cheers
lamboza is offline
Old 04-22-2009, 05:27 AM
  #3078
hi,i've looked around the forum and see that some charger have ac/dc
may i ask whats the difference between ac/dc?like charging directly from the socket or charging from socket extension
ruein is offline
Old 04-22-2009, 05:36 AM
  #3079
Nov
Nov's Avatar
Wall sockets provide AC power...
Chargers require DC power input...
There are some chargers that come with the AC/DC converter, so you need not purchase an additional AC/DC converter...Chargers like EX15, T15, etc...
The higher end chargers do not come with AC/DC converter, hence you need to get one...You can find them at Sim Lim Tower...Chargers like LRP Pulsar, Orion Advantage, Muchmore CTX, etc...
Nov is offline
Old 04-23-2009, 06:23 AM
  #3080
lamboza's Avatar
Default newbie
I did some search on the types of servo and found there are quite alot of types. such as metal gear, digital servo(low-profile), mirco servo, high speed servo and brushless servo.
Any helps from bros? cos i am confuse for their functions.
Cheers
E10 Rtr
3PM-FS 75mhz
lamboza is offline
Old 04-23-2009, 06:36 AM
  #3081
Dear all,
i was unable to fix the HPI T-Drift with rims (brought from winnie ,that 4 for SGD2 type)
i had try all the possible way to get them fix to my rims and below are the way i use
1. i use hot water(just boil) n put these tires in for 3 min
2. use hair dryer....and blow till the tires reli soft
3. microwave....2minutes...
okay...all of the above are able to make the tires soft...but when i try to fix it....it just cant fix it accurately. my hand is red n pain...even i step on it also cant.
is that any other way??? or the Rims not match that tires???
Thank you very much for your answer......very very appreciate.....
sprig is offline
Old 04-23-2009, 06:52 AM
  #3082
Trader Rating: 14 (100%+)
Originally Posted by sprig
Dear all,
1. Hair-dryer method - http://www.youtube.com/watch?v=jpnT6SNdQcM
2. Hot water method - http://www.youtube.com/watch?v=BJeBOQiRs54
and also please make sure that the rims are 26mm in width.
psychophant is offline
Old 04-23-2009, 07:22 AM
  #3083
thanks for the info,my main charger recently spoiled and i bought this BC-40 slow charger to sustain my batt,it says ac input and dc output,so i'll plug it directly to the main socket right?
ruein is offline
Old 04-23-2009, 07:50 AM
  #3084
Nov
Nov's Avatar
If your charger looks like a power plug, why not try pluggin in?
If its just 2 wires for input, then most likely its DC input...
Nov is offline
Old 04-23-2009, 11:53 PM
  #3085
Hi psychophant, thank for your suggest, i do try that also
but it seen not working. i think i will go home measure my rims again.
how much for those type t-drift +rims
sprig is offline
Old 04-24-2009, 12:32 AM
  #3086
HPI T-Drifts are 26mm in width. your rims have to be same width too.
You can either buy the T-Drifts and rims seperately or buy a pre-installed set of T-Drifts + rims which costs approx $50 for a set of 4.
Old 04-25-2009, 12:23 AM
  #3087
Red face New New Bird............
Hi All, New Bird here izzit ok to buy 2nd R/C Car to start?? or i just go n buy new One? i more like to DRIFT Style Need alot of advices from Old bird here.....oops Btw any Bro wanna sell TT01 model with full set??? cos i seach alot of forum All Bro sayin TT01 is Good for beginner like mi so i duno wherether izzit
NicesDrift is offline
Old 04-25-2009, 12:33 AM
  #3088
Movi$tar's Avatar
im same like u,so i bought a second handed TL01 to play...
but mayb the chassis has already has some slight cracks on it,so it breaks down now,supporting on glue n cable tie now...
so it all runs down to ur pocket,if it allows it,get a new one,fix it up urself...
anyway a normal drifiting car doesnt cost much,try the place i PM u,quite alot of stuffs over there...cheers n upzzz for ur new hobby!!!
Movi$tar is offline
Old 04-25-2009, 01:54 AM
  #3089
lamboza's Avatar
Default Neon lights
Jus wondering y my neon light won't light up when i insert the 9v in.. however when i bought from the uncle. he tested and it lighted up.. Wad could be the possible reason ? Thx alot. Jus 2 connections..
lamboza is offline
Old 04-25-2009, 03:02 AM
  #3090
Default Hotwheels 1:18 F1 Car (Year 2000)
Got 4 of Year 2000 1:18 scale Hotwheels F1 die cast still in box. The 4 cars are
1) Mika's McLaren
2) Eddie Irvine's Jaguar
3) Michael Schumacher's Ferrari
4) Ralf Schumacher's Williams
and another Jordan Mugen Honda (Damon Hill)
Each selling $15, self collect at Toa payoh. SMS 92707279
Attached Thumbnails Newbies Queries - Ask and you shall be answered!-img_0144.jpg
Markovich is offline
