Go Back  R/C Tech Forums > International Forums > Singapore R/C Racers
Newbies Queries - Ask and you shall be answered! >
Like Tree1Likes
Old 04-15-2009, 07:59 PM
  #3061
wenjie's Avatar
Originally Posted by Nov
Most touring cars have harder front springs than the rear...
But for drifting, most people prefer softer front springs to allow more weight transfer to the front during off-throttle hence easier to swing the car around...
Stock springs, silver in color? That should be considered as soft...
How come touring is hard front soft rear?Sorry.newbie in touring
wenjie is offline
Old 04-15-2009, 08:09 PM
  #3062
wenjie's Avatar
This is one of my Mini 4WD.Do you think it can fit ABC shells?
Attached Thumbnails Newbies Queries - Ask and you shall be answered!-dsc00238.jpg   Newbies Queries - Ask and you shall be answered!-dsc00239.jpg
wenjie is offline
Old 04-15-2009, 08:52 PM
  #3063
Nov
Nov's Avatar
Higher speed in touring, there's more momentum than drifting...More weight will be thrown forward and might oversteer in a corner...
Also, if I'm not wrong...responsiveness decreases with softer springs...Making the car abit slower thru some corners...
Therefore, harder springs in front...Most pro-kit manuals would recommend harder springs front as default setup...
As for your mini, I'm not sure what car it is...Maybe some other bros can help you with it...
Nov is offline
Old 04-15-2009, 09:13 PM
  #3064
wenjie's Avatar
Its an Xpress Mini.Discontinued though.
wenjie is offline
Old 04-15-2009, 09:34 PM
  #3065
magoasti's Avatar
Talking Infos..infos...infos
Hi bros, does anyone here knows any good websites for research & info gathering in RC parts & hop ups? Thnks a million..
magoasti is offline
Old 04-16-2009, 04:44 AM
  #3066
Would balancing my weight, give me the same ride height all around?
I use friction shocks
grategenin is offline
Old 04-16-2009, 05:24 AM
  #3067
nameless's Avatar
rcmart.com
nameless is offline
Old 04-16-2009, 01:00 PM
  #3068
Originally Posted by nameless
rcmart.com
asiatees.com
Old 04-18-2009, 04:09 AM
  #3069
Can the Futaba S9551 servo be used with lipo batts?
Rcmart says "Ni-cd use only".. But i've read that some people are using the servo with lipos. So does anyone know which one is true?
WhOoPe3 is offline
Old 04-18-2009, 08:29 AM
  #3070
Silvialite's Avatar
Using the 9551 on my EP car with lipo currently. No problems. The battery type doesn't matter, it's the voltage.
Silvialite is offline
Old 04-18-2009, 01:28 PM
  #3071
Ok thanks!
WhOoPe3 is offline
Old 04-18-2009, 09:51 PM
  #3072
lamboza's Avatar
Default Newbie
Hi guys,
was wondering how do we check to see if the ESC is able to support up to how many T of motor ? And also advice for the motor T from which brand . Lastly how to know when to change the brush in the brushed motors? any visible signs ?
Thx alot.
Cheers
3PM-FS 75Mhz
E10- 350z
lamboza is offline
Old 04-19-2009, 04:35 AM
  #3073
Originally Posted by lamboza
Hi guys,
Thx alot.
Cheers
3PM-FS 75Mhz
E10- 350z
Look in your manual or read the description. And when your motor starts losing power fast, not preforming normally.
Old 04-19-2009, 08:49 PM
  #3074
Default Receiver to be use
hi there,
Are there any mini receivers on market I can use for both Digital and Anologue servos.
Presently I hv 2 Futaba digital and 2 stock Xray NT18 anologue servos (my guess they both are Hitec ones). Trying to use one MX-3 transmittor for both cars.
thanks
great_scott is offline
Old 04-19-2009, 08:52 PM
  #3075
Silvialite's Avatar
Originally Posted by great_scott
hi there,
thanks
IMHO, it should not be a problem to use any receivers with both digital and analog servos. The MX-3 receiver can take both digital and analog servos.
Just my $0.02. Kindly correct me if I'm mistaken.
