Go Back  R/C Tech Forums > International Forums > Singapore R/C Racers
Newbies Queries - Ask and you shall be answered! >
Like Tree1Likes
Old 04-14-2009, 01:08 AM
  #3046
adrictan's Avatar
Originally Posted by grategenin
I live 30mins away from where they meet. And I don't have regular rides there.
But I tried it anyways, nothing happened for now........
Finally I can take those S turns.
Also some people say they like to drift with both diffs locked on the TT-01. I tried that and got a lot of understeer. How much would I loosen it up? I don't have a track to tell.
What did u use to lock yr diffs? What springs did you use for the front and rear? What type of tires do you use? Anyway, it's no fun you just drift by yrself right? Go down to the nearest DM and learn from there.
adrictan is offline
Old 04-14-2009, 01:09 AM
  #3047
adrictan's Avatar
No problem la. My nimhs also have some at 8.4 something.
Originally Posted by sLowHoG
Thanks..but the batt is at 7.4v and it seems very high to be detected at 8.4v....i am using the cellpro 4s..the rest of the batts i have all reflected as 7.4
adrictan is offline
Old 04-14-2009, 04:25 AM
  #3048
was reading somewhere that say for a 9t brushless motor, its equivalent to a 18t brushed motor..issit true?
HuFFy is offline
Old 04-14-2009, 04:39 AM
  #3049
Depends what company. But generally it should be around 15-18
grategenin is offline
Old 04-14-2009, 08:00 AM
  #3050
Hi all. I'm planning to get a Novak 5.5T motor for my TA05. Can any1 enlighten me on what gearing to use so i don't burn the motor? I'm thinking of using 105/38.
WhOoPe3 is offline
Old 04-14-2009, 08:49 AM
  #3051
thanks bro....
sLowHoG is offline
Old 04-14-2009, 05:51 PM
  #3052
Does anyone know what setting the stock springs are on the TT-01?
Hard,medium?
And Should I go for red soft in the rear?
I drift, if that matters.
Old 04-15-2009, 07:26 AM
  #3053
wenjie's Avatar
Hard,medium?
For me,I prefer red soft in front and grey ultra hard +5mm cable tie as spacer.
wenjie is offline
Old 04-15-2009, 07:27 AM
  #3054
wenjie's Avatar
Mini chassis owners please help.
Is it true that a ABC mini shell cannot fit a M03 chassis?
wenjie is offline
Old 04-15-2009, 08:28 AM
  #3055
Nov
Nov's Avatar
The servo is positioned quite high on the M03, so there are some shells that might have fitting problems...
Nov is offline
Old 04-15-2009, 09:41 AM
  #3056
wenjie's Avatar
Means some cannot only?You got try what shell before?
wenjie is offline
Old 04-15-2009, 12:57 PM
  #3057
Really? Most ppl say that the front should be harder.
Do you know if the stock springs are hard or medium?
Old 04-15-2009, 05:39 PM
  #3058
Nov
Nov's Avatar
When I had my M03, I only use the standard M03 shells like Swift and Mini...Shells like Eunos roadster or S2k which is for M04, cannot be used...
If you go ABCHobby website, under the 1/10M body...They will write which shell is not available for M03 chassis...
I see that the wheelbase for all their shells are 208mm, so you need to use the shortest wheelbase for M03, which should be 210mm...
Nov is offline
Old 04-15-2009, 05:43 PM
  #3059
Nov
Nov's Avatar
Most touring cars have harder front springs than the rear...
But for drifting, most people prefer softer front springs to allow more weight transfer to the front during off-throttle hence easier to swing the car around...
Stock springs, silver in color? That should be considered as soft...
Nov is offline
Old 04-15-2009, 06:07 PM
  #3060
The stock silver ones are soft!??!?! Holy crap.
Anyways anyone happen to know how much a TEU-BK101 esc weighs, and a silver can motor?
Also how much would a huge ass receiver would weigh?
Length:48mm
Width: 38mm
Height:19mm
