Go Back  R/C Tech Forums > International Forums > Singapore R/C Racers
Newbies Queries - Ask and you shall be answered! >
Like Tree1Likes
Old 03-31-2009, 02:02 AM
  #2971
adrictan's Avatar
Originally Posted by lamboza
I would like to know whats the diff between brush motors n brushless. It seems that price is way to different. And also suggest motors for [e10].
Lamboza...You have to do your own research first. Search the threads in here. There's are many threads to answer some of your queries. It's quite tedious answering what ppl have answered over and over.
adrictan is offline
Old 03-31-2009, 06:18 AM
  #2972
lamboza's Avatar
Sry sry .. did some reseach on my own alr.. Thx
lamboza is offline
Old 03-31-2009, 07:33 PM
  #2973
magoasti's Avatar
Default Clarification needed...
Hi gd morning bros,
recently a friend of mine bought a 3rd party hop-up, its a front 1 way alu shaft and it works quite well but some told me not to use 3rd party products and recommended Tamiya's front 1 way unit & rear ball diff gear. Pls advice very clueless which is better & whats the diff? and i understand the Tamiya's front 1 way unit & rear ball diff gear is more costly than the 3rd party hop-up.
Thnx lots & lots. Cheers!
magoasti is offline
Old 04-02-2009, 02:05 PM
  #2974
StrikeFreedom's Avatar
Originally Posted by magoasti
Hi gd morning bros,
Tamiya's front 1 way unit & rear ball diff gear come wif original and acurate measurements ; somehw is expensive due to the brand too...
3rd party hop-up's measurements may not come wif correct and acurate measurements ; somehw may not fit for ur chassis and is cheaper than the original hopups...
StrikeFreedom is offline
Old 04-02-2009, 07:23 PM
  #2975
magoasti's Avatar
Oooo...Thnx. But still wanna know about its performance, how it affects the user.
magoasti is offline
Old 04-03-2009, 12:30 AM
  #2976
GTBB's Avatar
Trader Rating: 14 (100%+)
Default Drifting chassis
I'm getting excited see ppl drifting, may i know which is the best drifting chassis? or maybe i should say is all depends on the skill irregardless of chassis model?
belt driven better or shaft driven better? Need your input.
any drifter mind to share your experiance?
thankx
GTBB is offline
Old 04-03-2009, 12:44 AM
  #2977
Nov
Nov's Avatar
thankx
There's no best chassis, more of skill in driving and setting...The chassis choice will be important if you're the kind where you depend more on settings than pure driving skill...I'm the kind that depend on settings...
Chassis with more weight in the front (Like Pro-D, TA03F, TA05) makes it easier to swing around...But this doesn't mean other chassis cannot drift well...
Currently using a 416 for drifting cos I'm more of a hopup guy...So by getting the top end, I won't need to spend extra money to get hopups...
Shaft cars are more responsive on the throttle than belt cars...Personally I prefer a belt car for a smoother driving feel, particularly for motors faster than a 23T...
Nov is offline
Old 04-03-2009, 03:47 AM
  #2978
kaixxxx's Avatar
yeah like wad nov is saying there's no best chassis, but only best tuner.
if u know how to tune, even basic car like E10 can perform to its best.
For me i prefer shaft driven car, i like the feeling of having power in my hand.
kaixxxx is offline
Old 04-03-2009, 05:56 AM
  #2979
magoasti's Avatar
Default Charging batts with T15
Hi bros got a very annoying qn to ask(1st time usin a T15), coz recently a friend of mine juz passed me his T15 b4 going overseas and didnt explain quite in detail.. Got a 2400 & 3700 NiMH, my qn is when charging should i charge at 3.0A(as according to the manual) or 2.4A for 2400 NiMH & 3.7A for NiMH? :confuse
Thnx alot..
magoasti is offline
Old 04-03-2009, 06:02 AM
  #2980
magoasti's Avatar
Default Drifting enquiry..
Hi again Bros,
got another qn..hope u guys can shed some light...
magoasti is offline
Old 04-03-2009, 06:08 AM
  #2981
TorqueGt's Avatar
Hi again Bros,
I thought your question was answered earlier???
TorqueGt is offline
Old 04-03-2009, 09:08 AM
  #2982
kaixxxx's Avatar
Thnx alot..
nah, u can charge up to 5A for ur batts if u wan.
Advantage of charging high A:
-u can charge ur batt faster.
-more punch u will get from ur batt.
Disadvantage of charging high A:
-batt will die faster.
For ur case i think u can set ur T15 charger 4 to 4.5A, no problem with tat.
kaixxxx is offline
Old 04-03-2009, 09:48 AM
  #2983
Rza
Rza's Avatar
heloo.. im noob.. noob need help..
ok guys, im now using digital servos for my steering. ive got an extra tx and rx set for me to use. but the frequency is in AM.. its a sanwa blazer sth sth...
my servos are ko-propo ics-2363 or sth sth..
and futaba 9550
can i use that receiver in AM frequency with any of the two servo?
will it burn the RX or damage the servo in anyway?
please help. thank you..
noob i am, noob need help.
Rza is offline
Old 04-03-2009, 06:11 PM
  #2984
superior1's Avatar
Thumbs up
Thnx alot..
Bro,
I'm using a T15 Tahmazo charger.
If u want to charge a 2400 / 3700 NIMH bat, set it to 2.4A / 3.7A
That's simple.
Thxs
superior1 is offline
Old 04-04-2009, 03:02 AM
  #2985
XxFishBonexX's Avatar
Default about crystal
hi i have a qus..
i have a tx that can change up to 12 channel...
my tx n rx crystal is 09 27.175Mhz if i wanna buy a rx crystal for other car
with same channel 09 do i need to buy the same frequnecy 27.175MHz or
27.xxxMHz crystal ?? so i can just chance 1 of the 12 channel to play.
best regard
Noob
XxFishBonexX is offline
