Go Back  R/C Tech Forums > International Forums > Singapore R/C Racers
Newbies Queries - Ask and you shall be answered! >
Like Tree1Likes
Old 03-23-2009, 11:55 PM
  #2941
chaihot5's Avatar
Originally Posted by lamboza
Yep . the new r/c shop huh .. cool hahas thx man .roughly how much does the whole set cost ? $300 ?
Won't be that much. Why dun u drop by his shop an enquire?
Cheers
chaihot5 is offline
Old 03-25-2009, 12:04 AM
  #2942
lamboza's Avatar
yo guys .. i jus bought a RTR hpi E10 .. was wondering wads the difference between 190mm and 200mm . And also do i nid to adjust any setting or jus leave it to factory setting ? Lastly is it possible to do a led lighting system with E10 .
lamboza is offline
Old 03-25-2009, 07:54 AM
  #2943
Rohitx's Avatar
* The difference between 190mm and 200mm refers to the width of the car. EP cars are 190mm and GP cars are 200mm. But you can fit the 200mm body shell in your E10. You just need maybe a 10mm offset wheels.
* Settings i will leave it up to you. When i bought my TT-01D RTR. I left my settings the way it was. It drifted well. But now slightly i have changed. I locked the rear differentials. See what suits u best.
* Yes it is possible to have leds with your E10. Just ensure ur bodyshell has light buckets. If not you need to custom make your own light bucket. Buy some led lights and LED light unit. Can find in almost all hobby shops.
Rohitx is offline
Old 03-25-2009, 08:25 AM
  #2944
lamboza's Avatar
Oh ok.. i was wondering how to know when to change the tires?
thanks
lamboza is offline
Old 03-25-2009, 06:43 PM
  #2945
adrictan's Avatar
thanks
I"m not sure wht tires comes with your E10 but normally, we keep a few sets to play with on different surfaces. Tamiya Driftech, T-drift, etc.
adrictan is offline
Old 03-25-2009, 07:18 PM
  #2946
lamboza's Avatar
oh u meant different tires are used for different surface? cos mine using HPI drift tires (PVC types) and i used for smooth surfaces .. haha
if i go on road surface or MSCP do i nid to change to rubber tires or ?
lamboza is offline
Old 03-26-2009, 02:02 AM
  #2947
adrictan's Avatar
Rubber tires provide grip and are used for touring. U won't be able to drift with them. Some ppl use PVC on road surface bec it cheap. U can use t-drift on road but will more heart-pain bec it's more expensive.
adrictan is offline
Old 03-26-2009, 03:08 AM
  #2948
lamboza's Avatar
Thx bro , haha
lamboza is offline
Old 03-26-2009, 03:34 AM
  #2949
Silvialite's Avatar
Choose the type of tyres for the kind of surface and the speed you want to drift. PVC can be used on smooth surface as well, but the drifting speed will be slow as traction is minimal. Your car will only be wheel spinning.
Silvialite is offline
Old 03-27-2009, 12:50 AM
  #2950
lamboza's Avatar
Default Newbie
Whats the difference between using a alummiun shaft rather den the stock shaft .. and also is all motors fit for HPI E10 ? Does changing the Tx & Rx will make a better car ?
Cheers
lamboza is offline
Old 03-27-2009, 01:42 AM
  #2951
adrictan's Avatar
Most 1/10 size cars use 540 size motors. Your E10 as well. The aluminium shaft is considered a better option bec it will flex lesser than a standard plastic shaft. Less flex will mean more power. Changing tx & rx I think is good if you intend to stay in the hobby for long. You have more options to fine tune the car and to save multiple settings if you have other cars in the future. my two cents...
adrictan is offline
Old 03-28-2009, 12:28 AM
  #2952
lamboza's Avatar
Default Newbie
Oh ok .. any prefered tx & rx ? and cost of it ? thx
lamboza is offline
Old 03-28-2009, 04:35 AM
  #2953
adrictan's Avatar
I use a 3PM on 75Mhz. rx I use Futaba 75mhz R203HF HRS receivers. Good tx include 3PK, M11, DX3R. Still it boils down to preferrences and budget. Good tx costs between 300 - 600 bucks.
adrictan is offline
Old 03-28-2009, 10:05 PM
  #2954
Adam01Rule's Avatar
any1 know where to get carbon fiber chassis for TT-01 in singapore???
Adam01Rule is offline
Old 03-29-2009, 12:30 AM
  #2955
Aprila's Avatar
bro u can try woodland's vista point under Ethan. he got a thread here which goes something like "Humble shop in vista point." check it out with him, he's got shipment in soon.
-aprila
Aprila is offline
