Go Back  R/C Tech Forums > International Forums > Singapore R/C Racers
Newbies Queries - Ask and you shall be answered! >
Like Tree1Likes
Old 08-03-2008, 02:56 AM
  #2356
ANX
ANX's Avatar
Where can u get the cheapest nitro fuel in Singapore?
need some for my 1/8 truggy
ANX is offline
Old 08-03-2008, 03:00 AM
  #2357
Tamiya1218's Avatar
Trader Rating: 16 (100%+)
helping friend to asking where to servic and repair the KO EX10 controller?
Tamiya1218 is offline
Old 08-07-2008, 06:08 PM
  #2358
hi, you can get the sidewinder from rotor hobby.... is close to $40 only.... 25% nitro.... most of the PORT guys are using this... so far so gd...
Cheers
MelvinSeet is offline
Old 08-07-2008, 06:10 PM
  #2359
In fact you can look for Sanwa Wong, very gd service... I used to pass him my KO-propo EX1 and servo for repair.... but i dun have his no. now... you can ask around for his no. most of the RC guys should know him.
Cheers
Old 08-07-2008, 07:47 PM
  #2360
GTBB's Avatar
Trader Rating: 14 (100%+)
Default Mamba max
hi, may i know which LHS got sell Mamba Max product with reasonable price? i'm new with brushless system. or any others brand of brushless system which can be use on off road?
thankx
GTBB is offline
Old 08-14-2008, 05:35 AM
  #2361
AsusEpoxy's Avatar
Default Hyperion 0606i AC/DC
recently got this charger, but my batteries seem to be having false peaks, can any expert advise what could i possibly be doing wrong?
AsusEpoxy is offline
Old 08-15-2008, 03:00 AM
  #2362
skyblueblue's Avatar
Default Kyosho Shock
Had a bad crash on my kyosho ZX-5.
Any bro know if Toykar or any LHS has the shock stay or wats it call in the pic that broke off ?
Replacement parts or need to get new shocks ?
Attached Thumbnails Newbies Queries - Ask and you shall be answered!-sl270684.jpg
skyblueblue is offline
Old 08-15-2008, 08:40 AM
  #2363
alana07's Avatar
Trader Rating: 53 (100%+)
u can try ask BK....
alana07 is offline
Old 08-21-2008, 10:12 PM
  #2364
hardrider's Avatar
Trader Rating: 40 (100%+)
Battery connection sequence could be wrong.
Try the main power leads first and then the balancing connector.
hardrider is offline
Old 08-24-2008, 12:14 AM
  #2365
anyone have the following tamiya track?
Scania R470 Highline ITEM 56317
just to know the colour of the track. TS-?
thanks hp 92712891
xc wong is offline
Old 08-24-2008, 12:16 AM
  #2366
Default ???
want to spray this colour on my hauler
thanks hp 92712891
xc wong is offline
Old 08-24-2008, 06:04 AM
  #2367
Originally Posted by kevpang
Hi all,
Just got a TT01D a mth ago n enjoying every moment of it.
But recently i find my stock damper getting softer n softer...it work great on some road surfaces but then again, the under chassis really get it rough if the road surface arent that appealing.
Been looking for more info on dumper set up but couldnt find much of it so i was hoping some kind souls can assist me on some qns;
  • For drifting, which system (Eg: Hard front & rear or Soft front & Hard rear etc etc) is more suitable?
  • Changing the damper oil to hard...which grade (The no. grading on the bottle)is more suitable as there r so many types on the market...its kinda confusing.
Thats all i can think of as i still a newbie drifter....any additional info is deeply appreciate.
Thks!!
Which damper are you using? If you are using the CVAs, you could upgrade the oil seals to TRF grade. They are much more flexible than the green oil seals. In fact you could upgrade all the parts on the CVAs to TRF which makes them perform better.
I don't know if Tamiya oil loses viscosity after use but Winnie recommends Trinity as they specialise in making shock oil.
Set up wise, it is an individual thing. And every surface/track needs different set up.
hermanchauw is offline
Old 08-25-2008, 07:48 AM
  #2368
Default List of all Rc shop location in singapore
Hi bro,
Just wanted to check with you, do u have the listing of all the rc shop location. if possible can u pm me.
Please advise if i wanted to buy spare part for 1/10 scale electric car where is the best price that u will recommanded more stock and is cheaper, thank you.
Cheers
Mr Tan is offline
Old 08-26-2008, 01:03 AM
  #2369
'm having a problem with me T15 power up charger. When i select Nimh chargin n press the enter button for 5 sec( basic procedure), the screen will go into the battery check and will either Hang there or will go back to main menu when its suppose to start charging. Happens to all my batteries and i can't figure out what is the problem as there is no error msg. Can any1 advise me on how to rectify or can reccommend where i can send the charger for repair if need to??
snyper is offline
Old 08-26-2008, 04:21 PM
  #2370
Default tmaxx 3.3 problems
my tmaxx 3.3 seems like when i give it full throttle it kinda just make like a puubaaa like its going to die like im really not sure what to do with it i tried adjusting the gas intake and that stuff and im also need advice on the spur gear i don't know if i should get a medal spur gear or stick with plastic they keep getting the teeth ripped off
Dilleo22 is offline
