Go Back  R/C Tech Forums > International Forums > Singapore R/C Racers
Newbies Queries - Ask and you shall be answered! >
Like Tree1Likes
Old 07-07-2006, 06:07 AM
  #1516
KOLORS's Avatar
Originally Posted by wpmanamx
Hi, Don't have any idea which pipe to use on my engine (OS .12TZ 5 port). Any recommendation? Thanks!
i see a lot of guys using the sage pipe on that engine...
KOLORS is offline
Old 07-07-2006, 08:31 AM
  #1517
Default Pipe for OS .12 TZ 5 port
Thanks KOLORS....
any idea where i can get sage pipe? Thanks again!
wpmanamx is offline
Old 07-10-2006, 11:40 AM
  #1518
BIOMASS's Avatar
where to buy much-more product here in singapore? Thanks
BIOMASS is offline
Old 07-17-2006, 05:33 AM
  #1519
Default Wheel Alignment Tools
What tools should i purchase to align my wheels?
What will be the correct setting if there is any for my 1:10 on road car.
Your advise is appreciated. Thank you
Black_Widow is offline
Old 07-18-2006, 10:32 PM
  #1520
dirtdynamics's Avatar
If i enter a race locally, am i limited to use with subC cells?
And is there a 6 cell a limit (7.4) or can i go more?
Nevermind the weight issue etc...
dirtdynamics is offline
Old 07-19-2006, 10:17 PM
  #1521
Sp1ke's Avatar
bro... there hasnt been an issue cos everyone has been running the same thing... official sanctioned races will limit the use to only sub-c's ah... lipo domination has not been felt entirely yet... hehe..
Sp1ke is offline
Old 07-27-2006, 04:14 AM
  #1522
FT
FT's Avatar
Default Charger Recommendations
As I'm still very new to EPs and Chargers, still wondering what charger to get.
Currently using an analoge charger, GWS 2002.
But now I'm looking forward to LiPo cells as I'm tired of switching the usual SANYO AA 2500mah batteries for my EX10 every 2-3hours.
and I need a charger that can also charge for my Starter's 12v Lead batt.
I'm using a typical wall charger for it now, can't tell how much my lead cell have been charged.
So, I require a charger that can do the following:
- 3-4 LiPo cells charging
- 1-10 NiMh cells charging
- 12v Lead cell (No idea how to tell it's rating. Got my lead cell from sam.)
Any recommendations or tips to offer?
I'm currently looking at Prolux DigiCharge 104 and Prolux DigiCharge 144.
also, was recommended the Schulze isl 6-330d 'Chamaleon' by someone few months ago.
Any of you guys have any comments for these chargers?
FT is offline
Old 07-27-2006, 08:18 AM
  #1523
Wink Running in/break in
Hi all experts out there, me just got a Hyper 7 and doing the running in process. Like to find out from you guys who know about this buggy on how many tank best to go to consider breaking in? So far i have done around 7 tanks and still dare not go full trottle. How can i tell whether my buggy has run in?
Thanks all
RJNG is offline
Old 07-27-2006, 08:21 AM
  #1524
Nov
Nov's Avatar
Default 200mm bodies...
Sorry to ask this very noob question...
I like to ask whether the 200mm is meant for width of chassis?
And those HPI 200mm bodies are compaitable with what kind of chassis...Mainly TA-05 or only chassis from HPI?
Nov is offline
Old 07-27-2006, 08:50 AM
  #1525
FT
FT's Avatar
The width from the far right to the far left side of the wheels.
If you were to put a 190mm body onto a 200mm car, your wheels will be poping out a little bit. Quite noticeable, but dosen't reallllly affect much on cosmatics. But if you want that realistic-scale looks, do get the correct compatible size.
A rather similar scenario when a 200mm body fitting onto a 190mm car. Wheels will be machiam hidding inside.
FT is offline
Old 07-28-2006, 06:59 AM
  #1526
Nov
Nov's Avatar
Hey thanks!
I like to ask...Does most of the chassis have the same length between the front and rear tires? Mainly like TA-05 and some chassis from HPI?
Nov is offline
Old 07-28-2006, 05:26 PM
  #1527
Thanks KOLORS....
Hi wpmanamx,
You can buy the Sage pipe @ Hobby Paradise, Old Nelson Rd.
Cheers
cjaguilar is offline
Old 07-29-2006, 07:52 AM
  #1528
Default Sage Pipe
Originally Posted by cjaguilar
Hi wpmanamx,
Cheers
Thanks Tops!
wpmanamx is offline
Old 07-31-2006, 08:09 PM
  #1529
Hi, i realise that Hitec servo requires a 3Amp BEC to work properly. The BEC on the LRP F1 Pro that a friend is using gives 1.6amp max. Therefore it cannot handle the servo requirements. So, any suggestions..
BTW theres a blue power line from the esc, how to utilise that?
Old 08-03-2006, 08:39 AM
  #1530
Thanks all
Hi dude, 7 tanks should be more than enough/ I normally run in mine for 4-5 tanks and works well. Cheers
BOSS is offline
