Steering binding
Hi, need help here. I have this problem twice the steering of TF-5 sometimes binds. The car tends to sway either left or right depends on where u turn. I check the servo its ok, change the servo saver already, sanded the turnbuckles(so no binding) still the problem is there?
W/o servo attachment the movement is smooth. |
Could it be the servo itself?
Last time when I used an old analog S3003, it gave me similar problems...;) |
Originally Posted by Nov
(Post 3879748)
hi alan, check your servo centering.. your servo could be working but it might have a problem with centering.. :)
Originally Posted by DECK
(Post 3880091)
Originally Posted by SuperEk4
(Post 3882081)
check the servo its ok, change the servo saver already, ...
You mention changed the servo saver, to which brand? The original one was found faulty on a very fast driver's car a few months back. He had the "turn left keep left, turn right keep right" problem. Change to Kimbrough ok liao. If not, then must be your servo. |
where to buy "Kimbrough" servo saver
thanks! |
Originally Posted by Ray Lan
(Post 3882251)
TF-5 as in Kyosho TF-5?
change servo saver already
Check the kingpins that are holding onto the knuckles. Make sure that you do not tighten the kingpin screws.
Also, check the Ball cups that are holding to the Ball ends to make the steering work. They could be binding, or holding too tight to the balls. :confused::weird: No pun intended. Hmm... OR you could be driving too fast that your car is holding onto its balls. I mean Ball Ends. ALfie |
Originally Posted by hoppie
(Post 3884459)
u also very fast driver leh :lol::lol::lol:
But if you think i'm fast, which I really don't think... you should see my car hit the main straight corner... fly very fast into Bk's front door.:D Fast no use, must consistantly fast, buang one time jialat jialat, how fast oso no use... I still practicing. THIS guy is much faster, but I guess EK4 has found him. ;) Kimbrough Servo Savers are now marketed by Eagle brand. But if you walk into an R/C shop and ask for Kimbrough servo saver, the shop owner should know what you mean. These have different models to suit different servos. So to be safe, bring the servo along if its your first time buying. Elite, RCI, Rotor are the shops I know who has them :) |
Originally Posted by Alfie
(Post 3885650)
(Post 3886491)
Thanks for the compliment. :blush:
But if you think i'm fast, which I really don't think... you should see my car hit the main straight corner... fly very fast into Bk's front door.:D Fast no use, must consistantly fast, buang one time jialat jialat, how fast oso no use... I still practicing. THIS guy is much faster, but I guess EK4 has found him. ;) Kimbrough Servo Savers are now marketed by Eagle brand. But if you walk into an R/C shop and ask for Kimbrough servo saver, the shop owner should know what you mean. These have different models to suit different servos. So to be safe, bring the servo along if its your first time buying. Elite, RCI, Rotor are the shops I know who has them :) Btw i brought many Kimbrough servo savers for rainy days. |
Bro, your car spoilt already. Not good anymore
I think u better give it to me :lol: |
Originally Posted by hardrider
(Post 3887886)
I think u better give it to me :lol: too late I gv to Nick already. |
