1/4 Scale RC Motorcross Bike
looks cool bro! Keep me updated on when it is selling and where is it going to be sold!
thanks!
thanks!
It can be bought from these places already..
http://www.armodelling.com/ (manufacturer)
http://www.rc-motorradshop.de/
http://www.formbymodelshop.com/index...LAYCAT&catid=1
http://www.ultrahobbies.com.au/store/customer/home.php
Hope this helps.
Hope this helps.
hi
cool ....the ultrahobbies's one seem more reasonable $$, anyone ordered from them before? Reliable?
Did a calculation, to order direct 1 kit with shipping to Singapore from a source will cost about $930 before GST taxes by our local authorities ..... with shipping costing about 75 euro included ....
Anyone interested .... ? I am definitely in ....
Updates
Some Updates from Mr Antonio of AR Racing:
The motor required is for a 1/8", 3.175mm shaft and it can accept 540 size motor. The tyre is made by GRP.
PRODUCT DESCRIPTION
Main data:
Frame: 2mm aluminum sheet laser cut
Rear Suspensions: adopts an aluminum shock absorber coupled to a CNC machined
swing-arm, 6 positions possibility, adjustable spring pre-load, max travel 75mm
Front suspension: telescopic fork with the possibility to extract the spring from the
upper side, possibility to adjust the piston dampening using a proper screw, max travel
70mm
Steering: double con-rod activated using a spring link, possibility to adjust spring
preload
Stability: the bike is gyro stabilized using a patented gear mesh, the gyro is designed to
give the best stability on different surfaces
Tires: front and rear tire are produced and designed by GRP
Suggested add-ons for best performances (not included in the kit):
- Motors: Brushless 5000KV 100A peak or 5900KV 109A peak we are currently testing
6900KV too
- ESC: Mtroniks Genesis Ride 100A
- Battery: LiPo packs 11.1V 4000 mAh or 7.4V 6000 mAh, runtime: 11.1V>10 min. 7.4V >
20 min.
Performances: recorded off-road on flat surface using an Eagletree data-logger:
- @7.4V max speed 23 mph; max amp. 56A; max power 380W
- @11.1V max speed 39 mph; max amp. 97A; max power 890W
PRODUCT DESCRIPTION
Main data:
70mm
preload
6900KV too
20 min.
Damn cool man!! Can't wait to get my hands on it.
Anyone ondering for it?
Hey bro!
Thought oof ordering it? U ordering from where?
By the way, since i have 2 XT8 now, once haven run in fully yet and the other still NIB, i dun know which one to let go.
thought of letting go one of them soon..
hi
hi ordering from them direct ...... Ultra Hobbies seem to only send within Aus and Canada only leh .... btw I too have 2 similar cars, the Losi8T ..... one running and the other NIB ...... too many cars, not enough good weather to run them ....... will pm you more details ....
thanks for your kind help bro!
