Tools to take out screw
anyone know what good tools to take out screw that has be rounded on the top?
how much....?
how much....?
Have u tried hitting it with a screw driver at an angle yet?
damn....so sian now.
how much....?
how much....?
Use a cutting disc meant for the mini dremel. Cut a new groove, then use a flat head screwdriver to unscrew it. The cutting action might bite into the chassis cos you will want to get the groove bigger to get a better lock.
Hope this helps.
Hope this helps.
Originally Posted by etino
If this is a M3 size screw that it will be difficult to take it out, but what you could do is to use a countershunk drill bit or a 8 or 9 sized drill bit to drill the head off. Next, carefully use a size 2.5 drill to drill on the screw itself. I've done this a few time for my nitro engine mount on the bottom chasis. Since, I use a bolt instead.
Very simple to use, just drill a hole into the screw, turn the screw extractor in clockwise until you feel it have grap a hold of the screw, and turn anti-clockwise. The screw will be removed with the extractor.
But remember to buy good ones. Don't buy those 4pcs for $10 ones. Since for RC, most of our screws are M3-M4, just buy a good one at about $8 for that range of diameter and it can last really long.
Try All Tools Trading near Singapore Casket (quite expensive), or the hardware shop at the basement of sim lim tower.
Originally Posted by Nipple
I used to cut a slot too, then use a flat headscrew driver....until I bought screw extractor.
But remember to buy good ones. Don't buy those 4pcs for $10 ones. Since for RC, most of our screws are M3-M4, just buy good one at about $8 for that range of diameter and it can last really long.
thanks for info. roughly how much is the screw extractor???? wanted to buy one.
Hi, what about M2 screw? It there a extractor for this size?
If i remember correctly....about $8 for a piece.....
so what i will need is a drill then buy the screw extractor for S$8 lah. is this what you mean?
