Hobao hyper8 1/8 buggy
come across this buggy at one of the forum just trying to share.
http://www.rc-ms.com/forums1/index.php?topic=2038.0
more pic of the buggy
more pics
last 2
But thanks for the pics. have you got one?
i have got a GP half 8 mini inferno 09 . Dun intend to buy Hobao because didnt know abt the brand but Hpi is on my mind either the 1/8 buggy or the 1/10 buggy still cant decide.
Hope to get one soon so can join you guys.
hmm.. been out for quite awhile already mah isn't it?
I have been helping with my friend's Hyper8 for about 5 months now.
The stock pipe and engine is quite terrible.
I believe the engine is basically a hobao .21 normal crank case being fitted with a "thinner" but larger Inner Diameter(.28) liner and a .28 piston.
Exhust tempretures seems to be excessively high in my scenario.
But other than that, overall the buggy is fine. If you want to get a Hyper8 package, avoid the RTR and get the Pro Kit instead. Becuase my friend have been spending on almost every replacement and hopup parts that a Pro Kit already have, could have just bought a Hyper8 Pro Kit from the start and save the extra costs and trouble.
Most of the RTR Hyper8 components are very weak.
oh ya.. that "low profile" airfilter isn't very good. Lots of Dirt and grim easily made it way into the inner foam element. Well, so far.. haven't found any solutions for my friend as it isn't posing a big problem. But sooner or later, it will really give problems.
But if you were to want to get a Hobao buggy, my honest opinion - Get a Hyper7 package instead.
Inline Pipe of Hyper8 Pro Kit
Hi All
Any one here have experience on the inline pipe that comes with the Hyper8 Pro Kit? Is it good enough for my Nosram .21 engine? Any recommendation on good pipe for that engine?
By the way, do we put the venturi on the engine or we take it out for more power when running?
Thanks.
Thanks.
engine
Originally Posted by RC Everything
Hi All
Thanks.
Thanks.
So is there problem using the Hyper8 pipe? Less power? I have a RB2006 pipe but have not tested on it yet as I just break in the engine.
I also heard JP3 pipe is powerful... but how is the fuel consumption then?
Any suggestions for using the venturi or not?
Originally Posted by jimmyloh
venturi can use the 9mm or 8mm which will able to perform leh..
u can try the JP3 pipe...seen in action and is also cooler for the power plant..fuel consumption think should be ok....venturi can use the 9mm or 8mm which will able to perform leh..
You have a real wicked engine
Originally Posted by dr_catman
jimmy do you take part in the races at turf city, ie the upcoming one?
it's just a power plant not wicked engine....
Can take out the venturi totally? More power right? Any harm to the engine?
