EP buggy check in here
#16
thanks, but not a large collection lah
#17
you have loose gears on your df03? how come? got to be careful with the bearing size as they can be quite tricky.
i use ceramic grease provided in the kit. good enough and don't squeeze out too much
#18
My DI rear gearbox seems tight .
read from another website , too much grease in there cause drag and make motor work harder.
i guess i would have to remove the extra grease.
#19
If I remember correctly, the DI gear box when new is very smooth. Should not be tight. Maybe you take out the bevel gear connecting the rear gearbox to the propeller shaft and see if the drag is caused by the bevel or the main diff gear.
Also, please be sure to tighten your diff properly. They are not very good.
Another thing is that the spur gear cover don't seal well. I used some RTV silicon on my DI to really seal it.
No need to remove the extra grease lah. Run 1 pack all the grease will be fling off the gear liao.
#20
Thanks will try it out.
#21
#22
Anyone mount the on/off switch on outside of the chassis for DF03.
#23
i mount it inside with a rubber cover attached
#24
So still need to remove the body shell to acess the on/off switch?
#25
by the way what pinion do you run with the Dirt Tuned?
#26
yup kind of, cos you have to disconnect the battery as well.....i hate to remove body but no choice
#27
Here is my TL01 buggy pic. Mine is at the back and the front 1 is my friend.
Sorry for the poor image. Using HP camera to take while bashing just now.
#28
#29
how come this thread is so quiet?
#30
Not many ppl playing EP buggy? Btw Toonz where u play ur buggies?
