Starter box slow down
Old 11-05-2006, 11:19 PM
Default Starter box slow down
Hi,
I got this problem with my starter box.
- The spinning get slower, so i cant start my car.
- I was trying to charge the battery, charge for a day but the light indicator on the charger still showing green and red light, and the motor is still running very slow.
any idea what might go wrong? i will bring down to the circuit and try with my friend's battery to check it out. in the meantime i just curious if any of you ever experience this and i can find the answer directly..
thank you,
blaz is offline
Old 11-06-2006, 03:33 AM
FT
FT's Avatar
If your starter's battery is a Lead(pB) cell, it might be dying already. Time to change it.
Remember to change Lead cells every 2 years or as accordingly.
but if it's NiCad/NiMah, then it should be having a serious memory effect or it's time is up.
well, after switching a your friend's cells but situation is still the same, check your circuitry or maybe the Motor is dying.
Good Luck.
FT is offline
Old 11-06-2006, 05:34 PM
Good Luck.
Hi, I bought my Starter box less then 6 months, everything new include the battery. i think it is lead cell. those heavy and boxy type (correct if i m wrong).
I didnt have a chance to try using my friend battery only by this weekend.
thanks for your comment..
blaz is offline
