Go Back   R/C Tech Forums > International Forums > Singapore R/C Racers
Old 10-27-2006, 07:46 PM   #1
Default Knocking noise when steering to extreme + full throttle
I encounter this problem on my Cyclone S 1/10 EP TC. When I steer to the extreme and 'gun' the throttle, I get this loud knocking sound - 'thok thok thok thok'. Is this normal? I am using universal drive shafts in the front.
Karmon is offline   Reply With Quote
Old 10-27-2006, 10:43 PM   #2
Arahawak's Avatar
Trader Rating: 32 (100%+)
Check your universal drive pins if they are install correctly. If the pins holding the shaft is install incorrectly it may result in the knocking sound.
Support Bacteria - its the only culture some people have!
Arahawak is offline   Reply With Quote
Old 10-28-2006, 02:29 AM   #3
Its pre-assembled and it looks ok to me.
Old 10-28-2006, 06:54 AM   #4
Sounds like the UJ/dog bone is not properly seated within the cups. Its slightly popping out of the cups. Do check on all linkages and likes to ensure that the distance is within spec.
Cheers!!
K.I.S.S.
Keep It Simple Stupid
kerk is offline   Reply With Quote
Old 10-28-2006, 08:55 PM   #5
Thanks for the advice. I'll check those.
MGT won't stop going full throttle? jatoattack Rookie Zone 6 04-23-2008 10:06 PM
full throttle cut out lowndsie Electric Off-Road 4 05-12-2005 02:50 PM
full throttle btuner Electric Off-Road 3 04-02-2004 10:17 AM
car going to the right when going full throttle alucard13 Nitro On-Road 14 05-08-2003 02:38 AM
