Go Back  R/C Tech Forums > International Forums > Singapore R/C Racers
need help in fixing new engine v1s >
Old 10-14-2006, 07:14 AM
Default need help in fixing new engine v1s
hi! got a v1s car n trying to fix a force .12 engine, found out dat e engine is lower than e stock engine when mounted, any idea which type of engine mount should i get n where to get it from. so far dat is e only problem, shaft are of e same length no problem, engine are e same spec as os engine wat i mean is e mounting way. thks in advance.
WHEELER is offline
