TrakPower 4900 Lithium Race Packs!!!
TrakPower 4900 Lithium Polymer Race Pack
Factory Matched for every pack!!!
Features:
-4.7 mOhm 1/4 of the resistance of a Zapped NiCd
-4900 mAh 700mAh more capacity than the leading NiMH
-268g 40% less than most NiMH packs
-7.4V Nominal, 8.4V fully charged
-7V held under 100 Amp Load More Power
-10th-Scale Car Racing Fit
-Integral 4mm Gold-Plated connectors
The performance is nothing short of amazing! Imagine having your matched nimh packs power thru-out the entire race rather than only the first 2 mins!
More Power, Lighter weight, sturdier casing, lower price............
Please share comments and enquiries
Features:
May I ask, how do you connect a balancer between a charger and Li-po pack?
What is a good balancer that you will suggest?
Sorry for the noobie questions, arh....
Cheers!!
Cheers!!
I believe TrakPower will be coming up with a balancer in the near future for the packs. However, from all my experiences of lipos in cars, balancing is not necessary. Voltage difference is negligible.
Should you feel like putting the pack thru a balancing charge, i can do it at the track for you.
Cheers!!
Cheers!!
Lipo usually has a balancer tab which will plug into the balancer and the deans plug will go into the charger. So while it charges, the balancer will balance the lipo.
if u r refering to the older version of balancer which needs to be used with a charger, then i'm not so sure liao
Anyway 2s don't really need to balance so often. Think the discharge more direct ba Ususally i feel its the middle cells that will cause the imbalance cos of the heat and resistance
Wah!!! Thank you, Thank you for the reponse! Think I understand better now. Really appreciate!
Cheers!!
Cheers!!
Don't take it the wrong way, I just can't put it in proper words in an understandable way. It'll better if explanation can be done with on spot descriptions.
So when u employing me as ur consultant
Sorry this may sounds stupid, but how much is this match pairs of 4900 ?
sorry i jus found out the price on the web on his sig
http://www.radiocontrol-sports.com/p...94ece3f7eca284
The price is introductory, there might be an increase in future due to freight and taxes.
Ammo - can you ship these to Australia?
Hi,
I am able to ship internationally.
Your PM and Email are not available. Please email me at [email protected]
Please check email, i have replied
