Go Back  R/C Tech Forums > International Forums > Singapore R/C Racers
RCMC GP Club Race - Sunday, 15th March 2020 DISCOUNTED >
Old 02-14-2020, 09:58 PM
SG_RCMC's Avatar
Default RCMC GP Club Race - Sunday, 15th March 2020 DISCOUNTED
RCMC SG GP Club Race - Sunday, 15th March 2020 (Discounted due to incomplete GP National Round 1)
Venue: East Coast R/C Circuit
Circuit Spec: 2020 Small Circuit - Anti Clockwise
The Race will start at 08:00hrs and will end around 18:00hrs. This race is a GP Club Race with all results counting towards how much you can brag that you took the A main :-)
PLEASE CONFIRM YOUR ATTENDANCE BELOW
Deadline for entry: Wednesday March 11th, at 12pm
Class Rules
GP - 1/8 On-road nitro -- Engine: 3.5cc 2 stroke engine; Tank: 125cc; INS BOX must be used; General IFMAR rules applied; Heats: 7 min x 3 round with best round to count.
1/10 200mm Touring nitro -- Engine: 2.11cc 2 stoke engine; Tank: 75cc; INS BOX must be used; General IFMAR rules applied; Heats: 7 min x 3 round with best round to count.
1/8 GT Nitro -- Engine: 3.5cc 2 stroke engine, 5 ports, 7mm Venturi max. Tank:150cc; INS box must be used; General IFMAR rules applied; Heats: 7 min x 3 round with best round to count.
1/5 TC Open - Gasoline engine 23cc; 2 wheel drive; rubber tyre; Refueling not allow; TC bodyshell; 535mm wheelbase. The race consists of heat 10min x 3 rounds with 3 consecutive best lap of either round to count and a 30min final.
1/5 F1 Open - Gasoline engine 26cc; 2 wheel drive; rubber tyre; Refueling and tyre change is allow only once (if needed) and must at split interval of at least 1 lap. In the pit 1 car max 1 Mechanic; pit lane speed less than 15km/h. The race consists of heat 10min x 3 rounds with 3 consecutive best lap of either round to count and a 25min final.
Race Fees for 1 / 2 / 3 classes respectively
Members: $20 / $30 / $35
Non-members: $30 / $45 / $55
This race will be confirmed if there are 20 or more entries in total, across all classes. After deadline, all entries listed on the RCTECH thread are committed to attending or paying their race entry fee to the RCMC regardless of actual attendance. The intent of this policy is to facilitate race logistics and most importantly, to give those who sign up confirmation that they will race on Sunday.
Format:
Bump Up Finals Format.
A-final: 40min; B-final: 30min, C-final: 20min
Final A - 10 Cars: 7 Drivers qualify directly (Qualifying positions 1st to 7th). 3 remaining positions bump up from B-Final race result (1st, 2nd and 3rd place respectively take 8th, 9th and 10th places on starting grid).
Final B - 10 Cars: 7 Drivers qualify directly (Qualifying positions 8th-14th). 3 remaining positions bump up from C-Final race result (1st, 2nd and 3rd place respectively take 8th, 9th and 10th places on starting grid).
Final C - Minimum 5 Cars: Remaining drivers take positions from qualifying results (15th to 25th).
More finals can be run should the driver turnout increase, minimum amount of cars per final is 6.
NOTE ON FINALS FORMAT: It is proposed that all mains will have 7 direct qualified drivers based on the qualifying results. If there are 5 or fewer drivers in the subsequent lower main (B main or lower), then these drivers will automatically be bumped up to the next higher main. This means that the lower mains (B main and lower) will only be run if there are between 6-12 cars in that leg, of which the top 3 will bump up to the next higher main in order. This arrangement shall override the previous agreed points/trophy award. The eventual race winner shall be awarded full championship points and trophies, irrespective of which lower main(s) he might be starting from. Irrespective of any main final, there should be minimum 6 cars running, with a max capacity of 12 cars. Maximum capacity of 12 cars in the lower main will take precedence in the order.
Kindest Regards,
Your RCMC Singapore Team
SG_RCMC is offline
Old 02-14-2020, 10:00 PM
SG_RCMC's Avatar
Name / car / engine / PT / member / payment method
1/8 Onroad
1.
1/10 Open
No. Name / car / engine / PT / member / payment method
1.
1/8 GT CLASS
1.
1/5 Large Scale Racing Touring Car
1.
1/5 Large Scale Racing F1
1.
SG_RCMC is offline
Old 02-19-2020, 12:02 AM
1/8 Onroad
1. Patrick Ong/989/OS/Member
1/10 Open
1.
1/8 GT CLASS
1.
1.
1.
Patrick Ong is offline
Old 02-23-2020, 04:18 AM
JBSpeed's Avatar
1/8 Onroad
1/10 Open
1.
1/8 GT CLASS
1. Tony Mansfield / X-ray / OS / member
1.
1.
JBSpeed is offline
