SPEED. Urban RC Indoor Masters 2019 (17 - 18 Aug)
URBAN RC is pleased to announce details of our next exciting event.
This will be a 2-day extravaganza to be held at Heartbeat@Bedok on 17 – 18 Aug, 2019.
For the first time in Singapore, an R/C event will feature 2 R/C tracks and 3 different R/C competitions. It will be a wonderful opportunity to showcase our hobby/sport to a wider audience.
For onroad racers, the on-going Urban Touring Series (UTS) will move offsite for the first time with Round 5 to held on the indoor carpet surface. Apart from the usual UTS classes of TC 17.5T blinky and Formula 21.5T blinky, 2 special classes will be run, namely the Mini Class and Truck Class.
For offroad racers, the first ever Urban Carpet Buggy Masters will feature the 2WD and 4WD open classes.
Drifters will not be left out as we are joining forces with the drift community to host Round 1 of the 2019 Ladder to TDC Singapore, with the Open RWD and Battle Royale being the feature classes.
And if that is not enough, a public “Give-it-a-Go” track will also be setup to provide those who are new to the hobby with the chance to run hobby-grade radio control cars free of charge.
Rules for Onroad and Offroad Classes
Here are the rules applicable to the Onroad & Offroad Classes to be run at SPEED. Urban RC Indoor Masters 2019
ONROAD
1. Touring Car 17.5T Blinky
As this will be run as part of the 2019 Urban Touring Series (UTS), the UTS rules this class will be in use eg motors, weight, bodyshells etc. As this is a carpet race, the controlled tyre and additive will be announced in due course.
2. Formula 21.5T Blinky
Please refer here for the applicable UTS rules. Do note that the previously announced Round 5 of the UTS that was to be held on 25 Aug will now be held as part of this event on 17-18 Aug instead.
3. Mini Class
- Chassis : Open 2WD Mini
- Motor: Tamiya 15.5T or 17.5T motor on the UTS Approved List
- ESC : Open with non-boost mode showing blinking LED lights. If in doubt, please contact Urban RC
- Gear ratio : For Tamiya minis, max 20T (FDR 5.78). For other brands, min FDR of 5.78.
- Bodyshell : Open except no touring car type bodyshells. If in doubt, please contact Urban RC.
- Battery : Max 7.6v 2S Hard-Case Lipo Batteries Only. Charging must be in a Lipo Safety Bag, with a max charge Rate of 10amp, and voltage not to exceed 8.40v
- Tyres : TBA
- Min weight : 1280g
4. Truck Class
- Chassis : Tamiya TT01/E chassis only
- Motor : Tamiya 15.5T or 17.5T motor on the UTS Approved List
- Gear ratio: Maximum Allowed Spur: 55T, Maximum Allowed Pinion: 25T
- Bodyshell : Open truck bodyshells
- Tyres : TBA
- Min weight : 1450g
OFFROAD
1. 2WD Open Buggy Class
Chassis: 2WD buggies only
Motor: Open
ESC : Open
Tyres : TBA
Min Weight : 1474g (inlcusive of transponder)
2. 4WD Open Buggy Class
Chassis: 4WD buggies only
Motor: Open
ESC : Open
Tyres : TBA
Min Weight : 1588g (inclusive of transponder)
ONROAD
3. Mini Class
- Tyres : TBA
4. Truck Class
- Tyres : TBA
OFFROAD
Motor: Open
ESC : Open
Tyres : TBA
Motor: Open
ESC : Open
Tyres : TBA
Event Update - Tyres, and Minimum Ride Height
TYRES
Pls note that the rules regarding tyres for the various classes are as follows:
1. 2WD Open Buggy - Open Rubber Tyres
2. 4WD Open Buggy - Open Robber Tyres
3. UTS Touring Car Class 17.5T Blinky) - Team Powers 26R Pre-Glued Rubber Tyre Set (Must be purchased from Urban RC, $36 per set)
4. UTS Formula 21.5T Blinky - To be Advised
5. Mini Class - To be Advised
6. Truck Class - To be Advised
MINIMUM RIDE HEIGHT
To minimise potential damage to the carpeted racing surface, please note that minimum ride height rules will be in effect for both the offroad and onroad classes for this event. The minimum ride heights to be observed will be announced in due course.
Further, we would also like to advise participants to ensure that there are no loose under-chassis screws or unusual sharp protrusions from the bodyshell. Once again, this is to minimise potential damage to the racing surface.
MINIMUM RIDE HEIGHT
Race Fee Payment
To facilitate the confirmation of event logistics, we are requesting that all participants make full payment of their race fee at Urban RC by 9 August 2019. Late payment after 9 August will be subjected to a $5 surcharge per class of entry. Thank you for your understanding. If you are unable to make it down personally to Urban RC, please send us a Facebook Message or WhatsApp at 98321090 for our bank account details.
Thank you for your kind understanding.
TYRES
MINIMUM RIDE HEIGHT
MINIMUM RIDE HEIGHT
We are pleased to inform that the 4WD Mini Class (17.5T non-outlaw, blinky ESC) will now be run as an additional class to the event.
Tyres - Updates (in Red)
Please be advised of the following update on tyres for the event
TYRES
4. UTS Formula 21.5T Blinky - Open Formula Rubber Tyres
5. 2WD/4WD Mini Class - Open Mini Rubber Tyres
6. Truck Class - Open Truck Class Rubber Tyres
We are also pleased to inform that Urban RC will be offering the following promotional prices for the recommended tyres for the onroad classes:
Tamiya Mini Tyre Set (M-Grip Radial tyres, Mini wheels and inserts) @ $39 per set (30% off retail price)
Tamiya Formula Tyre Set (F104 Front/Hard tyres, F104 Rear/Soft tyres, and F104 Mesh Wheel Set) @ $32 per set (30% off retail price)
Tamiya Truck Tyres (Onroad Racing Truck Tyres) @ $22.50 for 4pcs (30% off retail price)
TYRES
Traction Compound & Minimum Ride Height
TRACTION COMPOUND
For the onroad event, the approved traction compound is the Hudy Carpet Gripper. No other compounds will be permitted. On Sunday, 18Aug, a traction sauce station will be setup and the Hudy compound will be provided for your use. Pls remove all other compounds from your pit table. For clarity, motor spray may not be used to clean your tyres.
MINIMUM RIDE HEIGHT
For the onroad race, the minimum chassis ride height and bodyshell to ground clearance will be as follows:
Touring Cars, Truck and 4WD Mini : 5mm
Formula & 2WD Mini : 3mm
Pls ensure that this is complied with fully. We will check this pre-race with the bodyshell mounted. This is to ensure minimal damage to the carpet surface during the event.
MINIMUM RIDE HEIGHT
