Go Back  R/C Tech Forums > International Forums > Singapore R/C Racers
RCMC GP National Series #2 - Sunday, 12th May 2019 >
Old 05-03-2019, 05:17 PM
SG_RCMC's Avatar
Default RCMC GP National Series #2 - Sunday, 12th May 2019
RCMC GP National Series #2 - Sunday, 12th May, 2019
Race Date: Sunday, 12th May, 2019
Venue: East Coast R/C Circuit
The Race will start at 08:00hrs and will end around 18:00hrs. This race is a GP National Series Race with all results counting towards the 2019 standings
PLEASE CONFIRM YOUR ATTENDANCE BELOW:
Deadline for entry: Wednesday 8th May 2019 at 12pm
Class Rules
GP - 1/8 On-road nitro -- Engine: 3.5cc 2 stroke engine; Tank: 125cc; INS BOX must be used; General IFMAR rules applied; Heats: 7 min x 3 round with best round to count.
1/10 200mm Touring nitro -- Engine: 2.11cc 2 stoke engine; Tank: 75cc; INS BOX must be used; General IFMAR rules applied; Heats: 7 min x 3 round with best round to count.
<<<REVISED>>> - Please let us know which GT category you wish to enter either on race day or on RCTECH here below:
1/8 GT Nitro -- NEW Spec' class (RCMC SG National points awarded, Guided by IFMAR rule)
GT Spec class:
1) GBS rules as per Ifmar (See attached picture in Round #1 Update))
2) 3.5cc 5 ports 7mm venturi max. INS Box compulsory
3) Clutch. Conventional buggy/off road and new style GT clutch allowed. No onroad centax clutch allowed.
4) 150cc fuel tank
5) Shaft driven 4wd chassis, min front kick up of 5 degrees
6) 2 speed gearbox on solid axle, front and rear Diff, no centre Diff. No overdrive gear ratio on either Diff.
7) Rubber tires only. Foam tires not allowed.
1/8 GT Nitro -- NEW Open Class (Full Race Day, Finals & Trophies)
1) No engine restriction
2) No body shell restriction
3) Only rubber tire
1/5 -- Gasoline Engine 23cc ; 2 wheel drive; rubber tyre; No refueling and no modification to fuel tank capacity (Safety); Touring car bodyshell. The race consists of Heat 7min x 3 round with best round to count and a 30min final.
Race Fees for 1 / 2 / 3 classes respectively
Members: $30 / $55 / $65
Non-members: $50 / $75 / $85
This race will be confirmed if there are 20 or more entries in total, across all classes. The deadline for entry is Wednesday, 23 Jan 2019 at 12 pm (noon). After this deadline, all entries listed on this RCTECH thread are committed to attending or paying their race entry fee to the RCMC regardless of actual attendance. The intent of this policy is to facilitate race logistics and most importantly, to give those who sign up confirmation that they will race on Sunday.
Format:
Bump Up Finals Format.
A-final: 40min; B-final: 30min, C-final: 20min
Final A - 10 Cars: 7 Drivers qualify directly (Qualifying positions 1st to 7th). 3 remaining positions bump up from B-Final race result (1st, 2nd and 3rd place respectively take 8th, 9th and 10th places on starting grid).
Final B - 10 Cars: 7 Drivers qualify directly (Qualifying positions 8th-14th). 3 remaining positions bump up from C-Final race result (1st, 2nd and 3rd place respectively take 8th, 9th and 10th places on starting grid).
Final C - Minimum 5 Cars: Remaining drivers take positions from qualifying results (15th to 25th).
More finals can be run should the driver turnout increase, minimum amount of cars per final is 6.
NOTE ON FINALS FORMAT: It is proposed that all mains will have 7 direct qualified drivers based on the qualifying results. If there are 5 or fewer drivers in the subsequent lower main (B main or lower), then these drivers will automatically be bumped up to the next higher main. This means that the lower mains (B main and lower) will only be run if there are between 6-12 cars in that leg, of which the top 3 will bump up to the next higher main in order. This arrangement shall override the previous agreed points/trophy award. The eventual race winner shall be awarded full championship points and trophies, irrespective of which lower main(s) he might be starting from. Irrespective of any main final, there should be minimum 6 cars running, with a max capacity of 12 cars. Maximum capacity of 12 cars in the lower main will take precedence in the order.
Kindest Regards,
Your RCMC Singapore Team
SG_RCMC is offline
Old 05-03-2019, 05:20 PM
SG_RCMC's Avatar
RCMC GP National Series Race #2: 12th May, 2019
1/8 GP Open (Layout A "Large" - Anti-Clockwise)
No. Name / car / engine / PT / member / payment method
1.
2.
3.
4.
1/10 Open (Layout A "Large" - Anti-Clockwise)
1.
2.
3.
4.
1/8 GT (Layout A "Large" - Anti-Clockwise)
1.
2.
3.
1/5 (Layout A "Large" - Anti-Clockwise)
1.
2.
3.
SG_RCMC is offline
Old 05-03-2019, 09:07 PM
mclarenwest's Avatar
1. Nelson Lee / ARC / OS
2.
3.
4.
1.
2.
3.
4.
1.
2.
3.
1.
2.
3.
mclarenwest is offline
Old 05-04-2019, 01:15 AM
SG_RCMC's Avatar
2. Tony Mansfield / Infinity / OS / PT / member
3.
4.
1.
2.
3.
4.
1.
2.
3.
1.
2.
3.
SG_RCMC is offline
Old 05-05-2019, 05:17 AM
3.
4.
1.
2.
3.
4.
1.
2.
3.
1. Kok keng / Genius / Abbate / PT / Member
2.Kelvin / Mecatech / Abbate / PT / Member
3. Frank / Harm / G230 / PT / Member
4. Ah Heng / Genius / Abbate / PT / Member
5. Jazz / Harm / Raijin / PT / Member
6. Dax / Genius / G230 / PT / Member
Kok keng is offline
Old 05-06-2019, 02:56 AM
SG_RCMC's Avatar
Dear Racers,
Can you please use your full names and details on the sign up sheet? We have to match data in the race control computer database and it’s all based on full names.
thanks in advance for enabling our race director to have more time with his family and garage, and less time shouting at the laptop!
cheers!
SG_RCMC is offline
Old 05-06-2019, 07:24 AM
1. Nelson Lee / ARC / OS / PT / member
3. Austin Wong / mrx6r / os / non member
4. Yee kok leong / V8 / OS / non member
5. Billy cheah / RX8 / OS / non member
6.
1.
2.
3.
4.
1.
2.
3.
1. Kk / Genius / Abbate / PT / Member
2.Ky / Mecatech / Abbate / PT / Member
3. FT / Harm / G230 / PT / Member
4. Heng / Genius / Abbate / PT / Member
Old 05-06-2019, 08:51 AM
[QUOTE=mclarenwest;15444820]
6.
1.
2.
3.
4.
1. Patrick Ong / XRAY / WERKS / Member
2.
3.
Patrick Ong is offline
Old 05-06-2019, 09:02 AM
6.
1.
2.
3.
4.
2.
3.
Old 05-06-2019, 09:26 AM
Thumbs up
6.
1.
2.
3.
4.
2. CK Lee / Serpent / Nova / non member
3.
ck960 is offline
Old 05-07-2019, 03:47 PM
6. Wui Kiat/ shepherd/ Gimar/ member
7. Ericster Boon/ mugen/ gimar/ member
1.
2.
3.
4.
3.
backplate is offline
Old 05-08-2019, 03:45 AM
1.
2.
3.
4.
3.
6. Francis / Harm / G230 / PT / Menber
williamsoh is offline
Old 05-09-2019, 10:15 AM
[QUOTE=williamsoh;15445874]
1.
2.
3.
4.
3. Ericster Boon / Mugen / Nova / Member
4. Pason Phua / Serpent / Nova / Member
Old 05-09-2019, 09:43 PM
8 Don chng/ xxxxx/ / OS/ member/- 4619579
9. Daniel / V8/ Max/
1.
2.
3.
4.
Old 05-10-2019, 04:37 AM
[QUOTE=backplate;15446964]
1.
2.
3.
4.
1.
Kok keng is offline
