Go Back  R/C Tech Forums > International Forums > Singapore R/C Racers
2018 RCMC ISTC Electric Nationals - 21 Oct 2018 >
Old 09-25-2018, 11:31 PM
SG_RCMC's Avatar
Default 2018 RCMC ISTC Electric Nationals - 21 Oct 2018
Dear EP racers
The title of 2018 Singapore ISTC National Champion will be contested in a one-off race on 21 Oct 2018 at the RCMC East Coast Track. This event will be run alongside the Arrowmax Cup event scheduled for the same day.
The event details are as follows:
Date: Sunday, 21 Oct 2018
Time: From 9am onwards
Race Fee: $30 (RCMC Members) / $40 (Non-Members)
Class Rules:
  1. Motor: Open
  2. ESC : Open to all ESCs commercially available in the market.
  3. Gear Ratio: Open
  4. Batteries: Lithium Polymer 2S hard case, max 7.6v battery pack. Lipo batteries may be inspected before each run to ensure that the pre-race voltage readings do not exceed 8.40v; or 7.2V 6-cell Sub-C sized batteries
  5. Tyres / Inserts: Muchmore Rush 36X Pre-Mount 36 Deg (4 tyres with wheels and yellow inserts) (MM-RS-PMA36X-Y). Race tyres must be purchased trackside from RCMC on raceday only @ $32 per set. For practice, the tyres will be available trackside from RCMC at $38 per set on Sat, 20 Oct. The controlled tyres will also be available at selected local hobby shops prior to the race weekend.
  6. Number of Tyre sets : For the race, a maximum of 2 sets may be used (qualifying and finals).
  7. Tyre Additive: Racers can only use the Hudy Tire Gripper (#106260) as the traction compound during the event. This controlled additive will be provided during the event at no additional cost. Saucing may only be done at the designated area before each run. No other tyre treatment will be permitted (including use of brake cleaners etc) except for re-gluing of tyres. Tyre warmers are permitted.
  8. Minimum Weight: 1320g including transponder
  9. Body: Saloon bodies meeting the following requirements:-
  • Maximum width without body: 190 mm
  • Maximum width with body: 200 mm
  • Maximum wheelbase: 273 mm
  • Minimum height: 115 mm
  • The rear wing including endplates must not extend higher than the roofline.
Register for the class below
Name / Chassis / PT#
1. Nicholas Lee / Yokomo / TBC
2. Dominic Quek / Xray / TBC
3. Auyong / TRF / 8199032
4. PY Tang / ARC / TBC
5.
SG_RCMC is offline
Old 09-26-2018, 12:12 AM
SG_RCMC's Avatar
Dear EP racers
Class Rules:
  1. Motor: Open
  3. Gear Ratio: Open
  5. Tyres / Inserts: Controlled Tyres will be announced in due course
  6. Tyre Additive: Controlled Additive will be announced in due course. Saucing may only be done at the designated area before each run. No other tyre treatment will be permitted (including use of brake cleaners etc) except for re-gluing of tyres.
  7. Minimum Weight: 1320g including transponder
  8. Body: Saloon bodies meeting the following requirements:-
5. Barry Ng / ARC / TBC
6.
7.
8.
9.
10.
SG_RCMC is offline
Old 09-30-2018, 05:46 AM
mclarenwest's Avatar
Dear EP racers
Class Rules:
  1. Motor: Open
  3. Gear Ratio: Open
6. Nelson Lee / Yokomo / TBC
7.
8.
9.
mclarenwest is offline
Old 10-01-2018, 06:01 PM
Trader Rating: 4 (83%+)
Dear EP racers
Class Rules:
  1. Motor: Open
  3. Gear Ratio: Open
7. Hasron / Xray / 6207290
8.
9.
zerozero is offline
Old 10-03-2018, 10:59 PM
SG_RCMC's Avatar
Dear racers,
RCMC is pleased to inform that the controlled tyres for the event is the following:
Pls see the updated rules on post #1 of this thread for race pricing and availability.
SG_RCMC is offline
Old 10-05-2018, 01:24 AM
SG_RCMC's Avatar
Please be further advised that racers may use a maximum of 2 sets of the controlled tyre for the race (inclusive of both qualifying and finals).
Post #1 above has been updated accordingly.
SG_RCMC is offline
Old 10-11-2018, 10:11 PM
Dear EP racers
Class Rules:
  1. Motor: Open
  3. Gear Ratio: Open
8.Eugene Goh/ Yokomo/5296150
9.
Eugene goh is offline
Old 10-12-2018, 02:55 AM
SG_RCMC's Avatar
Racers, pls note that the controlled additive for this event is the Hudy Tire Gripper (#106260). The controlled additive will be provided at the tyre saucing area for racers' use during the event.
Post #1 has been updated accordingly.
SG_RCMC is offline
Old 10-14-2018, 06:23 PM
SG_RCMC's Avatar
Racers
Please note that the above layout will be run for this weekend's RCMC EP ISTC Nationals, in the ANTI-CLOCKWISE direction.
SG_RCMC is offline
